Folks,
It's been quite a while since I've interacted with this community; my long recovery from heart valve replacement surgery has somewhat dampened my enthusiasms. So, let me recap.
Back in the Summer of 2014, I went to Home Depot to look for LED lamps to replace nine 60 Watt incandescent bulbs in a nearly inaccessible chandelier (and not at all accessible in my current, fragile state as I don't want to risk falling two storeys into the front hall). In their lightbulb section were many 800 lumen LED lamps, but none were under $30, which seemed a bit extreme. But on my way out, I noticed an end-cap display for the Quirky/GE Wink system, which included as a loss leader a kit consisting of a hub and two GE Link lamps for $29.99. Needless to say, I bought the kit and a bunch more lamps, for $13 each, got a friend to help, rigged up a multi-fold ladder across the hole in the floor in the upstairs hall, and we replaced the old incandescent bulbs with GE Link lamps, pairing them as we did it.
Eventually, I bought about forty more GE Links and various other HA devices, but I could never get the nine-lamp chandelier to work properly. One after another, lamps would drop-out and require re-pairing and, if I left the fixture powered-on, other devices in the mesh would stop working as well. This was the very early days of Wink, so I spent a lot of time with their techs, including driving to Quirky R&D headquarters in Schnectady, NY, just over an hour one-way, multiple times. But, eventually, they solved multiple issues, including firmware updates they pushed to the GE Link lamps, and my mesh, including the GE Links in the chandelier, started working properly.
Then, as everyone here probably knows, Ben Kaufman closed Quirky and sold Wink. For awhile, all was well, but when Wink was resold to the rapper will.i.am, it became obvious that I had to find another solution. Almost exactly two years ago, I switched to Hubitat and, generally, have been extremely satisfied. There are, of course, issues, but the platform is updated regularly (two updates, today, in fact) and rare severe problems are very quickly dispatched.
My largest issue back in October, 2019 was that most of my lamps were the original GE Links, and they behaved as badly with Hubitat as they had originally with Wink. To make a very long story short, I was told, in no uncertain terms, that the GE Link lamps only worked well with the Wink system, that their firmware violated any number of Zigbee standards, and that they would never be supported by Hubitat. This was repeated, and vehemently, by one of the founders of Hubitat, so I took him at his word and bought over fifty replacement lamps, most of them Sengled and Sylvania.
Meanwhile, a huge box of GE Link lamps has been shoved for a couple of years under a Hoosier cabinet in my dining room. So far, so good. The other day, my niece, who has been staying with me in the attic, asked if I had a couple of light bulbs as she wanted to populate an empty fixture. She started with one, grabbed it out of the box, and installed it. Meanwhile, I had to factory reset and re-pair one of the Sengled lamps, which had been left in an unstable state following a flicker from the utility. When I did so, the Sengled lamp re-paired properly, but my C-5 found a new device, and assigned it the "Advanced Zigbee Bulb" driver.
Even though it's far from the other devices in the Zigbee mesh, it works fine and responsively. I'd never heard of this newish driver, which I see goes back at least to the beginning of this year, but I thought to try re-pairing the nine chandelier lamps I haven't been able to replace and, lo and behold, these GE Link lamps, which I was told that Hubitat would never support, work perfectly and, in fact, they work better than they did under the Wink system (where they'd come on in ones and twos over a period of several seconds). Here's how they're detected:
- endpointId: 01
- model: SoftWhite
- application: 02
- softwareBuild: 2.0.2.8
- firmwareMT: 10DC-4701-02000208
- manufacturer: GE
There is a remaining issue, but it's minor: when I try to add any of these GE Link lamps to a dashboard, as individual devices, they don't show-up in the list of devices in the "add tile" dialog.
To say I'm delighted would be an understatement. Thanks again, Hubitat!
Jeff
