I'm trying to port a device driver and app from the Smartthings forum. It is to connect my Tesla to Hubitat.
I have it all working expect the presents sensor. My car doesn't have the homelink so I'm trying to use the Lat and Long to set my presence. Could use some help on that. Not sure if it is possible.
Hi there, have you used the code as is from smartthings?
i guess the devicehandler should be imported as driver, and the smartapp as "app"
i ask this because i have been using the above code as a smartthings user, but have migrated to hubitat today...
i have modded the code in smartthings, so perhaps i can help when i have gotten it to work in hubitat, if you can confirm that the above is the case...
I installed this and it works great for my rules. However, I noticed that setThermostatSetpoint values do not actually reflect the exact number in the app.
This is what I have figured out so far:
Set Thermostat Setpoint to Actual temp in app
77 goes to 77
76 goes to 75
75 goes to 73
74 goes to 73
73 goes to 72
72 goes to 72
71 goes to 70
70 goes to 70
69 goes to 68
68 goes to 68
67 goes to 66
66 goes to 64
65 goes to 64
Just wanted to bring it to your attention, if you didn't know already. Otherwise, its a fantastic integration.
i have installed the tesla connect app and got it to work, but only for some hours
i suspect that it is because the access token i use is only temporary; so how do i get a long lived one?, and should it be inserted in 'Input new access token when expired?', or 'URL (on your server) that holds new access token as generated from python script?'?, or both?
Theres a detailed discussion at the bottom of here
I've found Teslafi works, but it isn't free long term. There does seem to be a pyhton script TeslaPy but I haven't gotten that working yet, although my Linux skills aren't great
ive looked at this and it cannot run directly as it requires chromediver as others to handle the javascript that comes back from tesla.. so it cannot run directly on the hub.. you may be able to get it running remotely
as doucmented in the original thread teslapy no longer works.. they changed the way the login works and it hangs.. i had it working at one point on a server with python and pushed the token to a web location.. no longer viable.
