Temperature reporting in built-in ZXT-600 driver
Would it be possible to implement the auto reporting options in the Remotec ZXT-600 built-in driver?
source: Remotec_ZXT-600_Users-Manual-3417624.pdf
You can see the temp in attributes then simply display that attribute where you want. If it's not displaying for some reason, simply use the built in z-wave tool to set those parameters you have in your post then display the attribute.
Hi Rick, thanks for your reply. In fact, the device seems to report its temperature, but we don't know at which interval or temp difference. For more control there is this workaround:
But it would be better if the driver exposes the options in the preferences section.
