I think it's driver related. When switch to Generic z-wave Temperature/Humidity it works. When below driver is used it does not work. Is the driver wrong or is there still some bug in Notification ?.
* Philio PST02-1A 4-in-1 Multi Sensor Device Type
* Based on Philio PSM02 4-in-1 Multi Sensor Device Type by eyeonall
* AND PSM01 Sensor created by SmartThings/Paul Spee
* AND SmartThings' Aeon MultiSensor 6 Device Type
* Converted it for Philio PAT02-1B Temperature/Humidity sensor. /ChrBratt
* Added debug on/off option. /ChrBratt
metadata {
definition (name: "Philio PAT02-1B Sensor", namespace: "ertanden", author: "Ertan Deniz") {
capability "Temperature Measurement"
capability "RelativeHumidityMeasurement"
capability "Configuration"
capability "Sensor"
capability "Battery"
capability "Refresh"
capability "Polling"
fingerprint deviceId: "0x0513", inClusters: "0x5E,0x80,0x71,0x85,0x70,0x72,0x86,0x30,0x31,0x84,0x59,0x73,0x5A,0x8F,0x98,0x7A", outClusters: "0x20"
fingerprint mfr:"013C", prod:"0002", model:"000B"
/* tiles {
valueTile("temperature", "device.temperature", inactiveLabel: false) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("humidity", "device.humidity", inactiveLabel: false) {
state "humidity", label:'${currentValue} ${unit}', unit:"%"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
main(["humidity", "temperature"])
details(["humidity", "temperature", "battery", "configure", "refresh"])
preferences {
input description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Temperature Offset", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
input name: "debugOutput", type: "bool", title: "Enable debug logging?", defaultValue: false
preferences {
def installed() {
logDebug "Installed with settings: ${settings}"
setConfigured("false") //wait until the next time device wakeup to send configure command after user change preference
def updated() {
logDebug "Updated with settings: ${settings}"
unschedule()
if (debugOutput) runIn(1800,logsOff)
logDebug "parse() >> description: $description"
def result = null
if (description.startsWith("Err 106")) {
logDebug "parse() >> Err 106"
result = createEvent( name: "secureInclusion", value: "failed", isStateChange: true,
descriptionText: "This sensor failed to complete the network security key exchange. If you are unable to control it via SmartThings, you must remove it from your network and add it again.")
} else if (description != "updated") {
if (logEnable) logDebug "parse() >> zwave.parse(description)"
def myDesc
if( description.contains("command: 3003"))
myDesc = description.substring(0, description.length() - 7)
if (logEnable) logDebug "Removed chars from 3003() >> description: $myDesc"
else{
if (logEnable) logDebug "Telegram kept intact() >> description: $myDesc"
def cmd = zwave.parse(myDesc, [0x20: 1, 0x5E: 5, 0x5A: 5, 0x30: 2, 0x31: 5, 0x5A: 5, 0x70: 1, 0x72: 1, 0x80: 1, 0x84: 2, 0x85: 1, 0x86: 1])
if (cmd) {
result = zwaveEvent(cmd)
if (logEnable) logDebug "After zwaveEvent(cmd) >> Parsed '${description}' to ${result.inspect()}"
return result
// Event Generation
//this notification will be sent only when device is battery powered
def zwaveEvent(hubitat.zwave.commands.wakeupv2.WakeUpNotification cmd) {
def result = [createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)]
def cmds = []
// Only ask for battery if we haven't had a BatteryReport in a while
if (!state.lastbatt || now() - state.lastbatt > 24*60*60*1000) {
result << response(command(zwave.batteryV1.batteryGet()))
result << response("delay 1200") // leave time for device to respond to batteryGet
if (!isConfigured()) {
logDebug("late configure")
result << response(configure())
} else {
logDebug("Device has been configured sending >> wakeUpNoMoreInformation()")
cmds << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
result << response(cmds)
result
def zwaveEvent(hubitat.zwave.commands.multicmdv1.MultiCmdEncap cmd) {
logDebug "multicmdencap: ${cmd.payload}"
//def encapsulatedCommand = cmd.encapsulatedCommand()
//if (encapsulatedCommand) {
// zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x5E: 5, 0x5A: 5, 0x30: 2, 0x31: 5, 0x5A: 5, 0x70: 1, 0x72: 1, 0x80: 1, 0x84: 2, 0x85: 1, 0x86: 1])
state.sec = 1
logDebug "encapsulated: ${encapsulatedCommand}"
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityCommandsSupportedReport cmd) {
log.info "Executing zwaveEvent 98 (SecurityV1): 03 (SecurityCommandsSupportedReport) with cmd: $cmd"
state.sec = 1
def zwaveEvent(hubitat.zwave.commands.securityv1.NetworkKeyVerify cmd) {
state.sec = 1
log.info "Executing zwaveEvent 98 (SecurityV1): 07 (NetworkKeyVerify) with cmd: $cmd (node is securely included)"
def result = [createEvent(name:"secureInclusion", value:"success", descriptionText:"Secure inclusion was successful", isStateChange: true)]
result
def zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
logDebug "---CONFIGURATION REPORT V1--- ${device.displayName} parameter ${cmd.parameterNumber} with a byte size of ${cmd.size} is set to ${cmd.configurationValue}"
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd)
logDebug "PAT02: SensorMultilevel before def map temp/humidity ${cmd.toString()}"
def map = [:]
switch (cmd.sensorType) {
case 1:
// temperature
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
logDebug "Temperature cmd.scaledSensorValue ${map.value}"
map.unit = getTemperatureScale()
map.name = "temperature"
if (tempOffset) {
def offset = tempOffset as int
def v = map.value as int
map.value = v + offset
logDebug "Adjusted temp value ${map.value}"
logDebug "Adjusted temp value ${map.name}"
log.info "Temperature ${map.value}"
break;
case 5:
// humidity
map.value = cmd.scaledSensorValue
logDebug "Humidity cmd.scaledSensorValue ${cmd.scaledSensorValue}"
map.unit = "%"
map.name = "humidity"
logDebug "Adjusted humidity value ${map.value}"
logDebug "Adjusted humidity value ${map.name}"
log.info "Humidity ${map.value}"
break;
//map
createEvent(map)
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
logDebug "PAT02-1B: BatteryReport ${cmd.toString()}}"
def map = [:]
map.name = "battery"
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = false
log.info "Battery ${map.value}"
//map
state.lastbatt = now()
createEvent(map)
def zwaveEvent(hubitat.zwave.Command cmd) {
logDebug "PAT02-1B: Catchall reached for cmd: ${cmd.toString()}}"
def configure() {
logDebug "PAT02-1B: configure() called"
def request = []
request << zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, scaledConfigurationValue: 1) // Operation Mode 0=Fahrenheit 1=Celsius
request << zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, scaledConfigurationValue: 54) // Customer Function
request << zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 12) // Auto report Battery time 1-127, default 12
request << zwave.configurationV1.configurationSet(parameterNumber: 13, size: 1, scaledConfigurationValue: 12) // Auto report Temperature time 1-127, default 12
request << zwave.configurationV1.configurationSet(parameterNumber: 14, size: 1, scaledConfigurationValue: 12) // Auto Report Humidity Time 1-127, default 12
request << zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: 30) // The interval time for auto report each tick in minutes, default 30
request << zwave.configurationV1.configurationSet(parameterNumber: 21, size: 1, scaledConfigurationValue: 1) // The temperature differential to report in Fahrenheit. 0 means turn off this function, default 1
request << zwave.configurationV1.configurationSet(parameterNumber: 23, size: 1, scaledConfigurationValue: 2) // The humidity differential to report in percent %. 0 means turn off this function, default 5
request << zwave.wakeUpV2.wakeUpIntervalSet(seconds: 24 * 3600, nodeid:zwaveHubNodeId) // Wake up period
//7. query sensor data
request << zwave.batteryV1.batteryGet()
request << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 1) //temperature
request << zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 5) //humidity
setConfigured("true")
commands(request) + ["delay 20000", zwave.wakeUpV2.wakeUpNoMoreInformation().format()]
private setConfigured(configure) {
logDebug "setConfigured: ${configure}"
updateDataValue("configured", configure)
private isConfigured() {
getDataValue("configured") == "true"
private command(hubitat.zwave.Command cmd) {
if (state.sec) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
private commands(commands, delay=200) {
log.info "sending commands: ${commands}"
delayBetween(commands.collect{ command(it) }, delay)
def logsOff(){
log.warn "debug logging disabled..."
device.updateSetting("debugOutput",[value:"false",type:"bool"])
private logDebug(msg) {
if (settings?.debugOutput || settings?.debugOutput == null) {
log.debug "$msg"
