* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "RFLC Dimmer", namespace: "Evan", author: "Samir_Genius") {
capability "Initialize"
capability "Telnet"
capability "Switch"
capability "Switch Level"
capability "ChangeLevel"
command "sendMsg", ["String"], int
command "sendLevel", ["Brightness 0-255"]
command "sendDimLevel", ["Brightness 0-255"]
attribute "Telnet", ""
attribute "Switch", ""
attribute "level", ""
preferences {
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "DevID", type: "string", title: "Legrand RFLC Device ID"
// device commands
def on() {
sendEvent(name:"switch", value:"on")
initialize()
log.debug "Send LNZL"
sendEvent(name: "switch", value: "on")
def msg = "shutdown -h now"
log.debug "Sending msg = ${msg}"
sendEvent(name: "switch", value: "off")
sendHubCommand(new hubitat.device.HubAction("""$msg\r\n""", hubitat.device.Protocol.TELNET))
setLevel(100)
def off() {
sendEvent(name:"switch", value:"off")
initialize()
log.debug "Send OFF"
setLevel(0)
// General App Events
def initialize(){
telnetConnect('192.168.1.199', 23, null, null)
log.debug "Opening telnet connection"
def parse(String message) {
log.debug "parse: ${message}"
log.debug DevID + " is running parse()"
if(message.substring(0,9) == ">RG, " + DevID || message.substring(0,9) == ">CR, " + DevID){
log.debug "level >> " + Math.round(message.substring(11,15).toInteger() / 2.55)
sendEvent(name:"level", value: Math.round(message.substring(11,15).toInteger() / 2.55))
if(message.substring(11,15).toInteger() == 0) {
else{
def startLevelChange(direction) {
initialize()
if (direction == "up"){
sendMsg("RAMPG "+(DevID)+" 255 40")
else {
sendMsg("RAMPG "+(DevID)+" 0 40")
def sendMsg(String msg)
log.info("Sending telnet msg: " + msg)
return new hubitat.device.HubAction(msg, hubitat.device.Protocol.TELNET)
def setLevel(level, ramp){
sendEvent(name:"level", value:level)
if(level == 0) {
else{
initialize()
sendMsg("RAMPG " +(DevID)+" "+(int)(level*2.55) + " " + ramp)
def setLevel(level){
setLevel(level, 50)
def stopLevelChange() {
sendMsg("CRAMP "+(DevID))
def telnetStatus(String status){
log.warn "telnetStatus: error: " + status
if (status != "receive error: Stream is closed")
log.error "Connection was dropped."
initialize()
I'm trying to create a bidirectional telnet driver for my Legrand lighting control system. I need to parse the incoming messages to update the light level variables for each device.
The parse(message) method is only running for 1 driver at a time. Every device that has the driver needs to run the parse() at the same time, so that the level state is kept updated with the actual light level.
Any suggestions to improve this driver is appreciated.
