Hi!
I have two tzwp-102 connected to a hubitat hub. Both devices connects to the hub successfully and I can set/get values.
I am located in Sweden and one of the devices are reporting correct voltage e.g. 220-240 V => since the correct reported voltage the other values, current and power will also be correct.
The other device are reporting incorrect voltage e.g. 0.1-0.2 V. Since the voltage value is "incorrect" the value of current and power scales incorrect.
I have tested both devices in the same outlet e.g. I connected the working device to one outlet, then disconnected the working device and then connected the not working device.
Both devices are using the same driver (zooz power switch) and has been factory restored. The devices has also been excluded and rejoined to the hub.
I also factory restored the hub but there were no difference. Which concludes that the devices that reports "wrong" values is faulty or have wrong settings.
What do I do?
Log of the working device after rejoin:
dev:22022-06-26 13:46:45.161 infoZ-Wave command:BasicReport(value:255, targetValue:0, duration:0)
dev:22022-06-26 13:46:45.067 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 208, 128])
dev:22022-06-26 13:46:44.966 infoZ-Wave command:MeterReport(scale: 5, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 1, 58])
dev:22022-06-26 13:46:44.870 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 3, 156, 44])
dev:22022-06-26 13:46:37.289 infofingerprint mfr:"0176", prod:"0003", deviceId:"0003", inClusters:"0x5E,0x25,0x85,0x59,0x55,0x86,0x72,0x32,0x5A,0x73,0x70,0x2C,0x2B,0x98,0x9F,0x6C,0x7A"
dev:22022-06-26 13:46:37.285 debugbuilding fingerprint for unknown Z-Wave device...
dev:22022-06-26 13:46:35.245 debugconfigure() called...
Current States
- current : 0.317
- currentH : 0.317
- currentL : 0.313
- energy : 0.021
- energyDuration : Unknown
- power : 53.376
- powerH : 61.948
- powerL : 51.995
- switch : on
- voltage : 236.588
- voltageH : 237.202
- voltageL : 236.588
Log of the faulty device after rejoin:
dev:12022-06-26 13:45:14.790 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 8, 45])
dev:12022-06-26 13:45:14.693 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 111])
dev:12022-06-26 13:45:04.991 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 21, 167])
dev:12022-06-26 13:45:04.895 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 111])
dev:12022-06-26 13:45:01.691 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 12, 144])
dev:12022-06-26 13:45:01.590 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 111])
dev:12022-06-26 13:44:59.291 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 2, 131])
dev:12022-06-26 13:44:59.190 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 111])
dev:12022-06-26 13:44:57.593 infoZ-Wave command:MeterReport(scale: 5, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 14])
dev:12022-06-26 13:44:55.987 infoZ-Wave command:BasicReport(value:255, targetValue:0, duration:0)
dev:12022-06-26 13:44:40.621 infoZ-Wave command:BasicReport(value:0, targetValue:0, duration:0)
dev:12022-06-26 13:44:40.581 infoZ-Wave command:MeterReport(scale: 2, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 0])
dev:12022-06-26 13:44:40.555 infoZ-Wave command:MeterReport(scale: 5, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 0])
dev:12022-06-26 13:44:40.554 infoZ-Wave command:MeterReport(scale: 4, rateType: 1, scale2: 0, deltaTime: 0, previousMeterValue: [], meterType: 1, precision: 3, size: 4, meterValue: [0, 0, 0, 111])
dev:12022-06-26 13:44:33.488 infofingerprint mfr:"0176", prod:"0003", deviceId:"0003", inClusters:"0x5E,0x25,0x85,0x59,0x55,0x86,0x72,0x32,0x5A,0x73,0x70,0x2C,0x2B,0x98,0x9F,0x6C,0x7A"
dev:12022-06-26 13:44:33.467 debugbuilding fingerprint for unknown Z-Wave device...
dev:12022-06-26 13:44:31.323 debugconfigure() called...
Current States
- current : 0.018
- currentH : 0.018
- currentL : 0.018
- energy : 0.000
- power : 2.050
- powerH : 2.050
- powerL : 1.993
- switch : on
- voltage : 0.112
- voltageH : 0.112
- voltageL : 0.112
