I have been trying to connect some Tapo Matter devices to Hubitat. The P125M plugs and S505 Switch connect great using the instructions (Connect to Google home first, then add to Hubitat with Matter code generated in Google home). They respond to to commands and update status, even when status was changed locally at the device.
I can also connect the H200 hub this way and even a Motion sensor connected to the H200 but the Motion sensor doesn't update status in Hubitat. Google home sees the status update just fine. When I pull the motion sensor in using Matter, it sets the device type to "device". I tried to change that to "Generic Matter Motion Sensor" and "Generic Matter Switch" but it still doesn't change state when motion is detected. Google home see it just fine.
Same for the Tapo T310 Temperature Sensor
I also tried the Tapo integration App created by @djgutheinz (tpLink_Hubitat/Docs/releaseNotes at main ยท DaveGut/tpLink_Hubitat ยท GitHub) on Hubitat but it doesn't recognize the H200 Hub.
I have a work around to use a Virtual switch in Hubitat and have google trigger it with an automation, but that would not make it "local Control"
Any ideas?
