I took over a RA2 select house and I have taken over the unit with a new account. I am in the process of adding a Hubitat and as per my other installations, I want to add HomeKit; directly to the Lutron RA2 hub.
The problem that I am having is interesting. I can not add the hub to HomeKit because the old owner did and has not deleted his account (this is what I strongly suspect).
Has anyone run in to this and if so have they any solution?
There is a possibly good reason to integrate to HomeKit via Hubitat/Homebridge. Lutron products, even full RadioRA 2 that has a defined 'on' level, all come on at 100% when using the native Lutron integration. When using Hubitat/Homebridge the 'on' comes on to the last level.
The crazy thing is this is after a factory reset. They also have some Ecobee thermostats and the same thing. This is a real issue if Apple does not allow to reset a HomeKit device.
I have asked the previous owner to delete the bridges and the home account but I do not think he knows how.
Their service level is very high and the will be able to help you figure it out. You won't have to buy a new repeater. You may have to re-program if you've reset the device.
