Hi there,
I was wondering if anyone has had experience wall mounting tablets for fixed wall dashboards. I did a little research and found this company VidaBox
https://www.vidabox.com/kiosks/vidamount-fixed-wall-ipad-tablet-mount.html
They look really good but I was wondering if anyone has used similar solutions and what their experience was with them
Have 2 mounts from https://mbmounts.com/
No complaints
Man I wish I would have known about them before. I like there options better. I went with this for my Fire 7 Tablet. This mount isn't bad and comes with the short USB charging cable but I had to buy an extender cable that goes down inside the wall and pops out of the outlet directly below. It then plugs into a standard USB charger. The mount doesn't really clip into place around the power button and volume buttons so if you press on it on the right hand side, the cover moves a little. Does not effect the use of the dashboard at all so only a minor complaint.
https://www.amazon.com/gp/product/B084G7ZT3L/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I used a Dremel to notch out where the cable comes out of the face plate to make it a cleaner look.
