Any suggestions. on some shop lights that you can change the color?
I have a friend that just built a giant garage and wants
to be able to change the color of the shop lights sometimes he wants it very bright.
and sometimes he wants soft lighting.
Would like to control them using his phone
Any suggestions?
Does he really want RGB or is CT good enough?
If this is his only smart thing need, I'd tell him to stick with Home Depot's Hubspace line -- at least that stuff is available locally at Home Depots and for very simple needs, you could do a lot worse ecosystem-wise.
They definitely have Hubspace CT shoplights, but I didn't see any RGB ones (I admittedly didn't look too hard though).
No .. he does not need the rgb .. but wanted to change from 2700K-6500K
This looks like a great Solution. that's why I asked here.
Cause I didn't even know these existed! Thanks for the heads up!
I did find this ... but do not have great reviews ![]()
https://www.amazon.com/Feit-Electric-LED-RGBW-ADJ4000/dp/B0CPTJ3614
Are you referring to color, as in rgb? Or color temperature of a white bulb?
Does he have any specific goals or use cases in mind for these lights?
I think that whatever he gets, he should get spares. ![]()
