All my devices locked up and required a Hub power drop and reboot. it got even stranger that after init, it rebooted itself again. Below is where the database locked up. Anyone have any ideas?
sys:12021-05-31 09:07:01.503 am Firmware update for [:] failed.
sys:12021-05-31 09:07:01.467 am Firmware update for [:] failed.
dev:22332021-05-31 09:06:59.017 am errorjava.lang.RuntimeException: java.sql.SQLException: Connections could not be acquired from the underlying database! on line 1303 (parse)
dev:32022021-05-31 09:05:43.197 am warnDescription map not parsed: [raw:AFEB01000108210020C8, dni:AFEB, endpoint:01, cluster:0001, size:08, attrId:0021, encoding:20, command:0A, value:C8, clusterInt:1, attrInt:33]
dev:2472021-05-31 09:04:55.142 am errorjava.lang.RuntimeException: java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:1162021-05-31 09:04:55.136 am errorjava.lang.RuntimeException: java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22332021-05-31 09:04:55.038 am errorjava.lang.RuntimeException: java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:2472021-05-31 09:04:55.022 am errorjava.lang.RuntimeException: java.sql.SQLException: Connections could not be acquired from the underlying database! (parse)
dev:22352021-05-31 09:04:24.908 am errororg.codehaus.groovy.runtime.InvokerInvocationException: org.quartz.JobPersistenceException: Couldn't obtain job names: The database has been closed [90098-197] [See nested exception: org.h2.jdbc.JdbcSQLException: The database has been closed [90098-197]] on line 1387 (active)
