you sir are a saint. i was getting it from there but as webhook. going to try that now thank you
So i created a user in surv station that has the permission to change mode. i've entered it in - should it work in browser as a test?
i'm getting error {"error":{"code":105},"success":false}.
tried with and without {} on user and pass. obs xxx is changed
here's the url i get for external http://192.168.1.xx:xxxx/webapi/entry.cgi?api=SYNO.SurveillanceStation.ExternalEvent&method="Trigger"&version=1&eventId=2&eventName="This is external event2"&account="{account}"&password="{password}"
should i use external ip perhaps hmm
ok, you are close, just use notepad / textedit to auto replace all the quotation marks " with %22
I forget why you need to do this, but it works.
thank you so much so my original ones worked (webhook) without user pass but i just had to replace " with %20! lovely!
thanks again for your help I really appreciate it
No worries, Iām glad you got it working.
For those that have migrated from BI to SS, curious what caused you to make the switch and if you are still happy with SS?
