@marktheknife I tried the zigbee switch /outlet. Initially it pairs as device. But nothing I've tried seems to have any effect. I got this to try to make my sigled work. Which keep saying inactive. Ironically the 7 xiaomi devices I have work fine.
If you mean you got the sylvania smart+ plug so that it would act as a repeater for your sengled bulb, then you appear to be SOL if you got the A version of the outlet.
I can’t confirm anything in that thread above, I don’t have either version of the sylvania smart+ plug.
Sorry.
Here is a recent map of my zigbee network. The router in the top left is my xbee. The routers twoard the bottom middle are my 4 sylvania smart plugs (non A version). All but 5 of the endpoints are xiaomi devices. A mix of motion, door, water and temperature sensors.
As you can see they are routing fine through my plugs. Been this way for a month or more now with very few issues.
My hub (the C) is actually sitting in a corner of my basement. My Xbee is in my office on the top floor. The plugs are on the main floor and 1 upstairs so the mesh is pretty strong.
Also I think the plug requires a driver to be installed. I took the driver from smartthings and ported it over easily. You should be able to find it on google.
When I ordered it I didn't see any designation for a or not. Is there a repeater that works for sure?
@gavincampbell how did u make that map
iris plugs (model 3210-L) repeat zigbee signals. And they also have a separate z-wave radio in them that can work as a z-wave repeater too, so that's a bonus. Only the zigbee half of the device is capable of turning the switch on/off (i.e. it's a zigbee outlet that acts as a repeater, and also a z-wave repeater, in one device).
Securifi peanut plugs also repeat, according to what others have read. Search for threads with terms like "zigbee," "repeater," and "outlet" or "plug" to find out what others have used successfully.
The image that @gavincampbell posted is from an xbee device (as he mentioned). There's a thread that discusses everything you'll need to know re: xbee, too. The title of the thread is literally, "everything xbee."
Search the forums for Xbee... there are threads that will give you all the details about them. That is what you need to make that map.
Stay away from these if you are going to use xiaomi devices. I have 3 of them sitting next to me unplugged right now. They are great that they repeat both zigbee and z-wave but the xiaomi devices do not like them and will constantly drop off.
So try to find the smart+ non - a and probably be ok with xiaomi. Or get the iris fix the lights but loose the temp sensors. Not too good of options.
I have 3 of the -A versions. They seem to work fine (I only have one Xiaomi device so I'm not worried about the issues there). I did have to go in and manually set the driver to generic zigbee outlet.
Here is the fingerprint when they join @mike.maxwell :
manufacturer:LEDVANCE
model:PLUG
basicAttributesInitialized:true
application:01
endpoints.01.manufacturer:LEDVANCE
endpoints.01.idAsInt:1
endpoints.01.inClusters:0000,0003,0004,0005,0006,0B05,FC01,FC08
endpoints.01.endpointId:01
endpoints.01.profileId:0104
endpoints.01.application:01
endpoints.01.outClusters:0003,0019
endpoints.01.initialized:true
endpoints.01.model:PLUG
endpoints.01.stage:4
Good to know. Do you know for sure the xiaomi device is being routed through them? I had to use my xbee to see all the routing. I guess you can see by unplugging the outlet and if the device stops reporting for a bit, then it was being routed.
I'm not setup to map the network. I would guess the one Xiaomi device is not routing through them since the reports seem to be that there is problems with that. But for use as switched outlets they work fine.
I just got a Sylvania Smart+ outlet and I can't get the Device Discovery to find it so I came along searching the community. It is model 72922-A. One place in the thread says these don't work with Hubitat, then someone says it did? Do I keep trying or return it? Thanks!
I just reset and paired it again with Hubitat. It worked fine. I have the 72922-A version. Did you try pairing it closer to the hub? Also make sure it is in the pairing mode. Press the power button on the plug for 5 to 10 seconds until the indicator blinks.
It's working now - it's weird because it didn't show up during device discovery for me to name and all that, but then a little while later I was looking at devices and it was there in the list with the generic name so I guess it did find it! Thank you for responding!
What did you use to get that map of your zigbee network?
An Xbee.. everything xbee is located in this thread.
Hello All,
I know this is a very old thread but I thought it might be useful to post my experience with the Sylvania Smart+ model 72922-A plugs that I have. I'm new to Hubitat (about 4 days ) and I am migrating from SmartThings. I have 6 of these plugs and they functioned very reliably with ST and helped me to stabalize the reliability of the Singled bulbs I have. I even used one in an outside weatherproof housing to run my pool pump. So I was disappointed when I started having trouble with these plugs after pairing with HE. Any time I placed the plugs more than a few feet away from the hub they would become unstable. I read in that a lot of others have had trouble with the 72922-A plugs so I was worried I might be SOL. In a last-ditch effort to make them work, and not really knowing the consequences, I changed the Zigbee channel from 20 to 11. After restarting all my Zigbee devices everything seems to be working (3 of the 72922-A plugs and 2 Samsung ST buttons so far).
I'm not really sure what changing the Zigbee channel did or what the downside of the change may be, so if anyone would care to comment I would appreciate it. If you have the 72922-A plugs I hope this helps. YMMV.
Kindest Regards,
Mike
You want to avoid channel overlap with nearby WiFi and Zigbee networks. If you still have SmartThings powered on, then the problem is likely that it was also on channel 20. I haven’t had any problems with my Sylvania plugs, but do prefer Samsung for repeating for a large number of devices. They seem to be worth the extra cost.
Hi Ken,
Thank you for your reply. The diagram was very helpful. I have a Cisco Wifi commercial-grade AP near my Hubitat hub that is blasting out 2.4 GHz signal. Changing the Zigbee channel probably got me further away from the Wifi channel making it work better.
I've gotten almost all my Zigbee stuff added now and my Wifi is working fine so I guess I'm good to go.
Thanks again,
Mike
