Officially, no, but there is a community integration in the works for this:
This is the only way I'd use these bulbs, by the way, unless you have a second hub dedicated entirely to Zigbee bulbs (or at least no other type of Zigbee device) or they happen to be the only Zigbee devices you have on that network. They can pair directly to Hubitat, but at least the older generation (newer one might be better) are known to be problematic repeaters for other types of devices that might mess with your network. See this doc for more, in particular the note on bulbs at the end: https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Zigbee_Mesh
