I'm sorting out my workbench at the moment and my soldering station on/off is now controlled by Alexa, which is awesome.
I'll be adding in the spotlight over the soldering station shortly, but I'd also like to be able to change the HDMI input going to the monitor above my workstation.
This is a "dumb" monitor and only has a single HDMI connection, so I'm looking for something like this that I can control with Hubitat.
The Logitech hub has two extended reach IR repeaters on it. It's more expensive than the broad link but has full support. If you have other devices around that same area (TV, receiver, streamer, etc), it will control them as well which could be useful.
Yeah, this is part of the problem - the only thing in the entire room that won't be connected via Z-wave/ZigBee/WiFi/Ethernet is this HDMI switch, so it's looking like it's going to cost me about £60 in parts just to press a switch automatically
I guess the alternative is that I upgrade the monitor from an old 24" to a new 32", but go for a TV instead and just use the WebOS driver to change the inputs...
Or better yet, this one, which is a better size for sitting close to!
Depending on what your displaying you might be able to get the HDMI "auto sensing switch" to do the switch for you. It works well with device that are turned on/off, and will not work well with "always on" devices unless they turn off the HDMI port when "sleeping".
I know this is a US version, but it is powered via HDMI, so might not matter, or you should be able to find a similar device for UK vendor.
If you are a bit technical you should be able to use the maker api and a serial command to do the switching as well as poll state, which for me is more robust than ir
