Switchbot stops connecting
Hi, I've had Switch bot working fine for nearly two years with the drivers and and Switchbot hub. Now suddenly I'm getting the following in integration logs, and Hubitat doesn't see to control it any. NB: Using the switchbot app it all still works.
dev:17822024-12-16 21:03:44.690errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
dev:17822024-12-16 21:03:44.368errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
dev:17822024-12-16 21:03:40.845errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
dev:17822024-12-16 21:03:40.564errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
dev:17822024-12-16 21:02:41.899errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
dev:17822024-12-16 21:02:39.685errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 551 (method writeDeviceCommand)
dev:17822024-12-16 21:02:17.259errorgroovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden on line 523 (method readDeviceStatus)
I also have this same error.
I've tried getting a new token through the app but that doesn't help.
There's no indication on the switchbot status page that there's a problem.
It's now working again.
Some sort of problem at the switchbot server end probably.
As if by magic. Anyway, very encouraging that someone is listening!
There's now an entry on the switchbot status page about it.
