Before I start physically change a switch i thought i'd ask if anyone else has had this problem. I have a 3 way switch setup --
- Inovelli Smart switch SLZW30 (3 -way)
- Add-on switch
It was working fine for 8 months and all of sudden the physical rocker switch on the SLZW30 doesn't work. I can turn on/off using Z-Wave or the Add-on switch, just can't use the physical rocker on switch. I assume it's dead and needs replacing? Or is there something else?
