What type of switch device is best for 120 volt electrical fans with variable speed, timer and remote control?
This is a Lasko Cyclone fan with a Lasko remote. The fan and the remote both have on/off, 4 variable speeds and a 1-4 hour timer controls.
This is a floor stand fan with an AC power cord that plugs into a wall socket, not hard wired ceiling fan.
Probably Bond depending on the frequency the remote uses.
You could also bypass all that if you don't change the fan speed often with a relay. I have a fan in a room with a single switch. I have ZEN52 installed in the canopy. Switch input for main power, then one output to the lights and the other to the fan motor. The fan is AC though so I don't have any module for the fan.
If the module for the fan has separate inputs for the lights/fan, then you can go the same route. If it's one power wire into the module, with separate module outputs for the lights and fan, then you're SOL and the Bond bridge is your only option.
