Anyone have an idea why sunset triggers my pistons more than once?
I also get the same thing with a time event triggering twice.
@gopher.ny Maybe an HE thing issuing the event more than once?
Sunset
Every Hour
Sunset
Every Hour
what version of webcore?
The lastest you have up.
3.114 in WC
v0.3.114.20240115_HE - February 24, 2024' WC Piston
set logging to medium then pause / resume the piston and show me the logs
Paused/resumed both; not much there.
app:122024-02-27 13:21:25.865tracebroadcastPistonList sent
app:122024-02-27 13:20:21.718tracebroadcastPistonList sent
I do notice lately when pausing/resuming a piston I'll get a warning which isn't true.
are you in the northern or southern hemisphere?
on a separate thought, wild thought here, wondering if Hubitat is waking the piston up seconds before the actual sunset, say at :00 seconds when sunset calculation says :03 seconds, with the platform being much faster to execute than ST, there is a possibility the code executes before the actual sunset and the next sunset happens in a few seconds, thus the repeat run? meh, no… lol
Yes, I'm a Northerner
You hypothesis might work for one but the other one (Time Happens) fires a 2 minutes later.
you need to set the log to full and wait for sunset to happen (or alter the sunset to use an offset that puts it a couple minutes into the future for a shorter wait).
Then we can try and debug things…
I'll try that tomorrow morning.
Tried it tonight but WC still thinks I'm in the Pacific without a reboot.
WAF to consider.
if !WAF {
replace(H)
that’s bad
LE: bad coding, I meant
Tried to trick HE/WC this morning but even though the hub was now happy in Central Africa WebCore is smarter and still thinks I'm in the Pacific NW.
Some brilliant programmer saw that coming.
I'll wait for the real sunset tonight to catch the logs.
eez just a bug LOL
You can easily shift the sunset by simply using an offset. If 360 minutes to sunset, use an offset of negative 365 minutes so you only wait for 5 minutes. If after sunset, use positive numbers, you get the point
Ran only once, no logs produced in WC at Full.
just this as expected, app:15942024-02-28 10:31:00.271info ║║ Blinds evening delay -73
Last night it ran twice at sunset:
app:16552024-02-27 18:38:01.090info ║ Blinds Evening
app:16542024-02-27 18:38:00.917info ║║ Blinds Evening
What do the single and double bars mean in the Log string? Maybe a clue?
There is the same thing with the Good Day issue as it ran twice today:
app:16552024-02-28 08:18:21.233info ║ Good Day
app:16542024-02-28 08:18:19.657info ║║ Good Day
Both these scenarios execute the same 2 lines of code so that may be the issue; calling multiple Execute Piston?
We are talking about the logs the piston itself
produces in the piston view page, do you have anything there?
Ah, I turned on full WebCore logging where there was nothing in the system logs.
I had logging in the actual piston on and it ran only once.
I turned on logging in the WebCore app | Blinds Evening and Good Day piston and will capture those.
I forget those are there as I never access the WebCore app through the little expand arrows.
PS: Where do the app identifiers come from? I notice the logs show duplicate entries but each line says 1655,1654, not the same.
I can't find a list anywhere in the HE UI. Are they dynamic or do they point back to a piston?
This would give me a clue to the double execution.
I see the issue, and I'm testing a fix. Will post an update once testing is completed
Impressive. I really didn't have any hardcore trail for you to follow except the first log posts.
Just in time for daylight saving time madness.
