I am not sure that I understand the sunset part of the rule machine. Hubitat time is correct, my zip code is correct, time zone is good but the sunset time is one hour off. Sunset here is 7:48 but Hubitat says sunset is at 8:48. I can do the one hour before sunset and that should work but I'm wondering if I'm doing something wrong.
Weird .. Mine seems fine after checking .. try a different zip ?
That did it. I changed the zip code and changed it back. Thank you very much.
NP .. I am glad it worked
