I put a condition on my front door lamp to turn it off at sunrise. It turned it off but not on sunrise but later. Might be an hour later - I am not sure. I was wondering if this is because time on HE is off. Is it possible? And how should I fix it?
Location is possibly setup incorrectly in the hub settings page. Sunrise & Sunset are set from the location so it's important to put an accurate location in otherwise it'll be incorrect.
No need to guess whether you hub time is off; check Settings > Hub Details to see for sure. While you're there, make sure your time zone is correct and your latitude and longitude are reasonably close to you. These are used to calculate sun times.
If that doesn't help, consider sharing a screenshot of the app how you've configured it.
I probably fixed it by applying the Postal Code in Hub Details. Will see how it will go
I am in US, Illinois
