I have 3 zigbee sunricher wall panels from sunricher. (SR-ZG9001T4-DIM-EU) They pair directly and is recognized as rgbgenie zb-3026. The problem I have is that the rgbgenie only hawe tre groups while my panels have four. The first tre groups work fine but there is no child device four the fourth. Is there a way to ad a fourth child device?
No one?
the correct driver for this device is the RGBgenie Button Controller.
This is a dynamic endpoint driver but doesn't create any child devices, it's simply a button controller.
You may be able to manually switch to this driver then click the configure command while the device is awake.
If you can provide the fingerprint for the device you have I'll add it to the correct driver.
A fingerprint for the device can be captured by switching to the driver "Driver", then clicking the getInfo command while the device is awake, the fingerprint will be printed in the live logs.
But this is a 4 Group dimmer whith 4 Seans. The dimmer works fine with zb-3026 driver but it is just the fourth button/dimmer that doesn't work.
Is this what you want:
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0B05,1000", outClusters:"0003,0004,0005,0006,0008,0019,1000", model:"ZGRC-TEUR-005", manufacturer:"Sunricher"
Yes, thanks
This device should join using the RGBgenie Button Controller driver in platform 2.2.4
