I am almost close to turning off my ST... So I am looking for an idea to do something like this below
I made a water leak sensor out of a gocontrol contact sensor. I looked at the post briefly, but my eyes get bloodshot and I start to shake whenever a post leads me to THAT place. I almost started smoking again.
Most code ports easily from ST to Hubitat with few changes. Have you tried?
Do you have the SmartApp from the third (or first or any) post in the thread you linked to working on ST? If so, the code looks like it should work verbatim on Hubitat. I'm not sure about the "phone" input and would personally rather use notifications for this, so I'd be happy to help you modify the code to use Pushover, Hubitat to ST Notification Pusher, or a similar notification (or TTS) device of your choice if you're the same and don't want to or know how to do it yourself.
But the trickier part seems like it would be getting a multisensor/acceleration sensor to monitor your sump pump. If you've got that part working, I'd say the hardest part is over.
Sorry no I did not try, I do not skills to do this yet.
I don use to send SMS just Push notification or similar is enough
I Have ZOOZ-ZEN15 to power my sump Pump
Could you please check this link below
Ok, so I looked at that readme and the app is a bit different than I thought. Apparently, it relies on the Zen15 driver (DTH on SmartThings) to pretend it's an acceleration sensor and report anything above a specified wattage threshold as "active," then the app tracks if that happens too many times in the specified interval and notifies you.
I don't think there's a native driver that does that for a switch/outlet on Hubitat, though it certainly would be possible to write, modify, or port one that does. However, it seems to me that it would be better to simply rewrite the app to use power reporting from the device (or any one that supports it) unless there's some advantage to doing it with the driver that I don't see. It might be possible to rig something up in Rule Machine that does something similar, but I'm not sure how easy that would be. If I have time, I'll see if I can rewrite the ST app, but no guarantees.
In the meantime, it looks like that ST app would work verbatim, as long as you have a driver or can port a DTH from ST (should be easy but if you find one, but I'm sure lots of us would offer to help) that works how the app expects.
If there is still a need- this is a port of @krlaframboise Zen15 driver that includes the acceleration attribute ('Report as inactive if power is less than or equal to _") . I used it for several months before switching to the built in driver.
* Zooz Power Switch / Zooz Smart Plug v1.4
* (Models: ZEN15, ZEN06)
* Author:
* Kevin LaFramboise (krlaframboise)
* URL to documentation: https://community.smartthings.com/t/release-zooz-power-switch-zooz-smart-plug/97220?u=krlaframboise
* Changelog:
* 1.4 (12/17/2017)
* - Added Acceleration capability for detecting when power is on or off and setting for the active threshold.
* - Added overload protection override setting.
* 1.2 (09/09/2017)
* - The device seems to occasionallly report values that are way above a realitic value for some users so add a check that logs the value as a warning instead of creating events for it.
* 1.1 (09/06/2017)
* - Switched history to value tile to fix iOS bug.
* 1.0 (07/26/2017)
* - Initial Release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (
name: "Zooz Power Switch",
namespace: "krlaframboise",
author: "Kevin LaFramboise"
capability "Actuator"
capability "Sensor"
capability "Switch"
capability "Outlet"
capability "Power Meter"
capability "Energy Meter"
capability "Voltage Measurement"
capability "Configuration"
capability "Refresh"
capability "Health Check"
capability "Acceleration Sensor"
attribute "lastCheckin", "string"
attribute "history", "string"
attribute "current", "number"
attribute "energyTime", "number"
attribute "energyCost", "string"
attribute "energyDuration", "string"
["power", "voltage", "current"].each {
attribute "${it}Low", "number"
attribute "${it}High", "number"
command "reset"
fingerprint mfr:"027A", prod:"0101", model:"000D", deviceJoinName: "Zooz Power Switch"
fingerprint mfr:"027A", prod:"0101", model:"000A", deviceJoinName: "Zooz Smart Plug"
simulator { }
preferences {
configParams?.each {
getOptionsInput(it)
input "energyPrice", "decimal",
title: "\$/kWh Cost:",
defaultValue: energyPriceSetting,
required: false,
displayDuringSetup: true
input "inactivePower", "number",
title: "Report inactive when power is less than or equal to:",
defaultValue: inactivePowerSetting,
required: false,
["Power", "Energy", "Voltage", "Current"].each {
getBoolInput("display${it}", "Display ${it} Activity", true)
getBoolInput("debugOutput", "Enable Debug Logging", true)
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
tileAttribute ("device.acceleration", key: "SECONDARY_CONTROL") {
attributeState "inactive", label:'INACTIVE'
attributeState "active", label:'ACTIVE'
standardTile("refresh", "device.refresh", width: 2, height: 2) {
state "refresh", label:'Refresh', action: "refresh", icon:"st.secondary.refresh-icon"
standardTile("reset", "device.reset", width: 2, height: 2) {
state "refresh", label:'Reset', action: "reset", icon:"st.secondary.refresh-icon"
valueTile("energy", "device.energy", width: 2, height: 2) {
state "energy", label:'${currentValue} kWh', backgroundColor: "#cccccc"
valueTile("power", "device.power", width: 2, height: 2) {
state "power", label:'${currentValue} W', backgroundColor: "#cccccc"
valueTile("voltage", "device.voltage", width: 2, height: 2) {
state "voltage", label:'${currentValue} V', backgroundColor: "#cccccc"
valueTile("current", "device.current", width: 2, height: 2) {
state "current", label:'${currentValue} A', backgroundColor: "#cccccc"
valueTile("history", "device.history", decoration:"flat",width: 6, height: 3) {
state "history", label:'${currentValue}'
main "switch"
details(["switch", "power", "energy", "refresh", "voltage", "current", "reset", "history"])
private getOptionsInput(param) {
if (param.prefName) {
input "${param.prefName}", "enum",
title: "${param.name}:",
defaultValue: "${param.val}",
required: false,
displayDuringSetup: true,
options: param.options?.collect { name, val -> name }
private getBoolInput(name, title, defaultVal) {
input "${name}", "bool",
title: "${title}?",
defaultValue: defaultVal,
required: false
// Meters
private getMeterEnergy() {
return getMeterMap("energy", 0, "kWh", null, settings?.displayEnergy != false)
private getMeterPower() {
return getMeterMap("power", 2, "W", 2000, settings?.displayPower != false)
private getMeterVoltage() {
return getMeterMap("voltage", 4, "V", 150, settings?.displayVoltage != false)
private getMeterCurrent() {
return getMeterMap("current", 5, "A", 18, settings?.displayCurrent != false)
private getMeterMap(name, scale, unit, limit, displayed) {
return [name:name, scale:scale, unit:unit, limit: limit, displayed:displayed]
def updated() {
if (!isDuplicateCommand(state.lastUpdated, 3000)) {
state.lastUpdated = new Date().time
def cmds = configure()
return cmds ? response(cmds) : []
def configure() {
def result = []
updateHealthCheckInterval()
def cmds = []
configParams.each { param ->
cmds += updateConfigVal(param)
result += delayBetweenCmds(cmds)
if (!getAttrVal("energyTime")) {
result += reset()
else {
result += refresh()
return result
private updateConfigVal(param) {
def cmds = []
if (hasPendingChange(param)) {
def newVal = getParamIntVal(param)
logTrace "${param.name}(#${param.num}): changing ${getParamStoredIntVal(param)} to ${newVal}"
cmds << configSetCmd(param, newVal)
cmds << configGetCmd(param)
return cmds
private hasPendingChange(param) {
return (getParamIntVal(param) != getParamStoredIntVal(param))
void updateHealthCheckInterval() {
def minReportingInterval = minimumReportingInterval
if (state.minReportingInterval != minReportingInterval) {
state.minReportingInterval = minReportingInterval
// Set the Health Check interval so that it can be skipped twice plus 5 minutes.
def checkInterval = ((minReportingInterval * 2) + (5 * 60))
def eventMap = createEventMap("checkInterval", checkInterval, false)
eventMap.data = [protocol: "zwave", hubHardwareId: device.hub.hardwareID]
sendEvent(eventMap)
def ping() {
logDebug "Pinging device because it has not checked in"
return [switchBinaryGetCmd()]
def on() {
logTrace "Turning On"
return delayBetweenCmds([
switchBinarySetCmd(0xFF),
def off() {
logTrace "Turning Off"
switchBinarySetCmd(0x00),
def refresh() {
logTrace "Refreshing"
switchBinaryGetCmd(),
meterGetCmd(meterEnergy),
meterGetCmd(meterPower),
meterGetCmd(meterVoltage),
meterGetCmd(meterCurrent)
def reset() {
logTrace "Resetting"
sendEvent(createEventMap("${it}Low", getAttrVal(it), false))
sendEvent(createEventMap("${it}High", getAttrVal(it), false))
sendEvent(createEventMap("energyTime", new Date().time, false))
def result = []
result << meterResetCmd()
result += refresh()
return result
private meterGetCmd(meter) {
return secureCmd(zwave.meterV3.meterGet(scale: meter.scale))
private meterResetCmd() {
return secureCmd(zwave.meterV3.meterReset())
private switchBinaryGetCmd() {
return secureCmd(zwave.switchBinaryV1.switchBinaryGet())
private switchBinarySetCmd(val) {
return secureCmd(zwave.switchBinaryV1.switchBinarySet(switchValue: val))
private configSetCmd(param, val) {
return secureCmd(zwave.configurationV2.configurationSet(parameterNumber: param.num, size: param.size, scaledConfigurationValue: val))
private configGetCmd(param) {
return secureCmd(zwave.configurationV2.configurationGet(parameterNumber: param.num))
private secureCmd(cmd) {
if (zwaveInfo?.zw?.contains("s") || ("0x98" in device.rawDescription?.split(" "))) {
return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
else {
return cmd.format()
private delayBetweenCmds(cmds, delay=500) {
return cmds ? delayBetween(cmds, delay) : []
def result = []
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result += zwaveEvent(cmd)
else {
log.warn "Unable to parse: $description"
if (!isDuplicateCommand(state.lastCheckinTime, 60000)) {
state.lastCheckinTime = new Date().time
result << createEvent(createEventMap("lastCheckin", convertToLocalTimeString(new Date()), false))
return result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCmd = cmd.encapsulatedCommand(commandClassVersions)
def result = []
if (encapsulatedCmd) {
result += zwaveEvent(encapsulatedCmd)
else {
log.warn "Unable to extract encapsulated cmd from $cmd"
return result
private getCommandClassVersions() {
0x20: 1, // Basic
0x25: 1, // Switch Binary
0x27: 1, // All Switch
0x2B: 1, // Scene Activation
0x2C: 1, // Scene Actuator Configuration
0x32: 3, // Meter v4
0x59: 1, // AssociationGrpInfo
0x5A: 1, // DeviceResetLocally
0x5E: 2, // ZwaveplusInfo
0x70: 2, // Configuration
0x72: 2, // ManufacturerSpecific
0x73: 1, // Powerlevel
0x7A: 2, // Firmware Update Md (3)
0x85: 2, // Association
0x86: 1, // Version (2)
0x98: 1 // Security
def zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
def val = cmd.scaledConfigurationValue
def configParam = configParams.find { param ->
param.num == cmd.parameterNumber
if (configParam) {
def name = configParam.options?.find { it.value == val}?.key
logDebug "${configParam.name}(#${configParam.num}) = ${name != null ? name : val} (${val})"
state["configVal${cmd.parameterNumber}"] = val
if (configParam.num == overloadProtectionParam.num) {
refreshHistory()
else {
logDebug "Parameter ${cmd.parameterNumber} = ${val}"
return []
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
logTrace "SwitchBinaryReport: ${cmd}"
def result = []
result << createSwitchEvent(cmd.value, "digital")
return result
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
logTrace "BasicReport: ${cmd}"
def result = []
result << createSwitchEvent(cmd.value, "physical")
return result
private createSwitchEvent(value, type) {
def eventVal = (value == 0xFF) ? "on" : "off"
def map = createEventMap("switch", eventVal, null, "Switch is ${eventVal}")
map.type = type
return createEvent(map)
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
logTrace "MeterReport: $cmd"
def result = []
def val = roundTwoPlaces(cmd.scaledMeterValue)
def meter
switch (cmd.scale) {
case meterEnergy.scale:
meter = meterEnergy
break
case meterPower.scale:
createAccelerationEvent(val)
meter = meterPower
break
case meterVoltage.scale:
meter = meterVoltage
break
case meterCurrent.scale:
meter = meterCurrent
break
default:
logDebug "Unknown Meter Scale: $cmd"
if (meter?.limit && val > meter.limit) {
log.warn "Ignored ${meter.name} value ${val}${meter.unit} because the highest possible value is ${meter.limit}${meter.unit}."
else if (meter?.name && getAttrVal("${meter.name}") != val) {
result << createEvent(createEventMap(meter.name, val, meter.displayed, null, meter.unit))
if (meter.name == meterEnergy.name) {
result += createEnergyEvents(val)
else {
result += createHighLowEvents(meter, val)
runIn(5, refreshHistory)
return result
private createAccelerationEvent(val) {
def deviceActive = (device.currentValue("acceleration") == "active")
if (val > inactivePowerSetting && !deviceActive) {
sendEvent(name:"acceleration", value:"active", displayed:false)
else if (val <= inactivePowerSetting && deviceActive){
sendEvent(name:"acceleration", value:"inactive", displayed:false)
private createHighLowEvents(meter, val) {
def result = []
def highLowNames = []
def highName = "${meter.name}High"
def lowName = "${meter.name}Low"
if (!getAttrVal(highName) || val > getAttrVal(highName)) {
highLowNames << highName
if (!getAttrVal(lowName) || meter.value < getAttrVal(lowName)) {
highLowNames << lowName
highLowNames.each {
result << createEvent(createEventMap("$it", val, false, null, meter.unit))
return result
private createEnergyEvents(val) {
def result = []
def cost = "\$${roundTwoPlaces(val * energyPriceSetting)}"
if (getAttrVal("energyCost") != cost) {
result << createEvent(createEventMap("energyCost", cost, false))
result << createEvent(createEventMap("energyDuration", calculateEnergyDuration(), false))
return result
private calculateEnergyDuration() {
def energyTimeMS = getAttrVal("energyTime")
if (!energyTimeMS) {
return "Unknown"
else {
def duration = roundTwoPlaces((new Date().time - energyTimeMS) / 60000)
if (duration >= (24 * 60)) {
return getFormattedDuration(duration, (24 * 60), "Day")
else if (duration >= 60) {
return getFormattedDuration(duration, 60, "Hour")
else {
return getFormattedDuration(duration, 0, "Minute")
private getFormattedDuration(duration, divisor, name) {
if (divisor) {
duration = roundTwoPlaces(duration / divisor)
return "${duration} ${name}${duration == 1 ? '' : 's'}"
def refreshHistory() {
def history = ""
def items = [:]
items["energyDuration"] = "Energy - Duration"
items["energyCost"] = "Energy - Cost"
items["${it}Low"] = "${it.capitalize()} - Low"
items["${it}High"] = "${it.capitalize()} - High"
if (getParamStoredIntVal(overloadProtectionParam) == 0) {
history += "*** Overload Protection Disabled ***\n"
items.each { attrName, caption ->
def attr = device.currentState("${attrName}")
def val = attr?.value ?: ""
def unit = attr?.unit ?: ""
history += "${caption}: ${val} ${unit}\n"
sendEvent(createEventMap("history", history, false))
def zwaveEvent(hubitat.zwave.Command cmd) {
logDebug "Unhandled zwaveEvent: $cmd"
return []
// Configuration Parameters
private getConfigParams() {
return [
overloadProtectionParam,
powerFailureRecoveryParam,
onOffNotificationsParam,
ledIndicatorParam,
powerValueChangeParam,
powerPercentageChangeParam,
powerReportIntervalParam,
energyReportIntervalParam,
voltageReportIntervalParam,
electricityReportIntervalParam
private getOverloadProtectionParam() {
return createConfigParamMap(20, "Overload Protection", 1, ["Disabled (NOT RECOMMENDED)":0, "Enabled${defaultOptionSuffix}":1], "overloadProtection")
private getPowerFailureRecoveryParam() {
return createConfigParamMap(21, "Power Failure Recovery", 1, ["Remember last status${defaultOptionSuffix}":0, "Turn On":1, "Turn Off":2], "powerFailureRecovery")
private getOnOffNotificationsParam() {
return createConfigParamMap(24, "On/Off Notifications", 1, null, null, 2) // 2:Manual switch only
private getLedIndicatorParam() {
return createConfigParamMap(27, "LED Power Consumption Indicator", 1, ["Always Show${defaultOptionSuffix}":0, "Show for 5 seconds when turned on or off":1], "ledIndicator")
private getPowerValueChangeParam() {
return createConfigParamMap(151, "Power Report Value Change", 2, getPowerValueOptions(), "powerValueChange")
private getPowerPercentageChangeParam() {
return createConfigParamMap(152, "Power Report Percentage Change", 1, getPercentageOptions(10, "No Reports"), "powerPercentageChange")
private getPowerReportIntervalParam() {
return createConfigParamMap(171, "Power Reporting Interval", 4, getIntervalOptions(30, "No Reports"), "powerReportingInterval")
private getEnergyReportIntervalParam() {
return createConfigParamMap(172, "Energy Reporting Interval", 4, getIntervalOptions(300, "No Reports"), "energyReportingInterval")
private getVoltageReportIntervalParam() {
return createConfigParamMap(173, "Voltage Reporting Interval", 4, getIntervalOptions(0, "No Reports"), "voltageReportingInterval")
private getElectricityReportIntervalParam() {
return createConfigParamMap(174, "Electrical Current Reporting Interval", 4, getIntervalOptions(0, "No Reports"), "electricityReportingInterval")
private getParamStoredIntVal(param) {
return state["configVal${param.num}"]
private getParamIntVal(param) {
return param.options ? convertOptionSettingToInt(param.options, param.val) : param.val
private createConfigParamMap(num, name, size, options, prefName, val=null) {
if (val == null) {
val = (settings?."${prefName}" ?: findDefaultOptionName(options))
return [
num: num,
options: options,
prefName: prefName,
val: val
// Settings
private getEnergyPriceSetting() {
return safeToDec(settings?.energyPrice, 0.12)
private getInactivePowerSetting() {
return safeToInt(settings?.inactivePower, 0)
private getDebugOutputSetting() {
return settings?.debugOutput != false
private getMinimumReportingInterval() {
def minVal = (60 * 60 * 24 * 7)
[powerReportIntervalParam, energyReportIntervalParam, voltageReportIntervalParam, electricityReportIntervalParam].each {
def val = convertOptionSettingToInt(it.options, it.val)
if (val && val < minVal) {
minVal = val
return minVal
private getIntervalOptions(defaultVal=null, zeroName=null) {
def options = [:]
if (zeroName) {
options["${zeroName}"] = 0
options << getIntervalOptionsRange("Second", 1, [5,10,15,30,45])
options << getIntervalOptionsRange("Minute", 60, [1,2,3,4,5,10,15,30,45])
options << getIntervalOptionsRange("Hour", (60 * 60), [1,2,3,6,9,12,18])
options << getIntervalOptionsRange("Day", (60 * 60 * 24), [1,3,5])
options << getIntervalOptionsRange("Week", (60 * 60 * 24 * 7), [1,2])
return setDefaultOption(options, defaultVal)
private getIntervalOptionsRange(name, multiplier, range) {
def options = [:]
range?.each {
options["${it} ${name}${it == 1 ? '' : 's'}"] = (it * multiplier)
return options
private getPowerValueOptions() {
def options = [:]
[0,1,2,3,4,5,10,25,50,75,100,150,200,250,300,400,500,750,1000,1250,1500,1750,2000,2500,3000,3500,4000,4500,5000,6000,7000,8000,9000,10000,12500,15000].each {
if (it == 0) {
options["No Reports"] = it
else {
options["${it} Watts"] = it
return setDefaultOption(options, 50)
private getPercentageOptions(defaultVal=null, zeroName=null) {
def options = [:]
if (zeroName) {
for (int i = 1; i <= 5; i += 1) {
options["${i}%"] = i
for (int i = 10; i <= 100; i += 5) {
private convertOptionSettingToInt(options, settingVal) {
return safeToInt(options?.find { name, val -> "${settingVal}" == name }?.value, 0)
private setDefaultOption(options, defaultVal) {
def name = options.find { key, val -> val == defaultVal }?.key
if (name != null) {
return changeOptionName(options, defaultVal, "${name}${defaultOptionSuffix}")
else {
return options
private changeOptionName(options, optionVal, newName) {
def result = [:]
options?.each { name, val ->
if (val == optionVal) {
name = "${newName}"
result["${name}"] = val
return result
private findDefaultOptionName(options) {
def option = options?.find { name, val ->
name?.contains("${defaultOptionSuffix}")
return option?.key ?: ""
private getDefaultOptionSuffix() {
return " (Default)"
private createEventMap(name, value, displayed=null, desc=null, unit=null) {
desc = desc ?: "${name} is ${value}"
def eventMap = [
value: value,
displayed: (displayed == null ? ("${getAttrVal(name)}" != "${value}") : displayed),
isStateChange: true
if (unit) {
eventMap.unit = unit
desc = "${desc} ${unit}"
if (desc && eventMap.displayed) {
logDebug desc
eventMap.descriptionText = "${device.displayName} - ${desc}"
else {
logTrace "Creating Event: ${eventMap}"
return eventMap
private getAttrVal(attrName) {
try {
return device?.currentValue("${attrName}")
catch (ex) {
logTrace "$ex"
return null
private safeToInt(val, defaultVal=0) {
return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=0) {
return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private roundTwoPlaces(val) {
return Math.round(safeToDec(val) * 100) / 100
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (debugOutputSetting) {
log.debug "$msg"
private logTrace(msg) {
// log.trace "$msg"
