Suggestions on naming convention for devices, child devices, and mesh devices?
What are your suggestions on naming devices?
Initially, I had something long like this:
[floor][person][roomtype][device type]
eg: 1F Bob BR TempDisplay
This long name didn't fit well in the old Dashboard. At least with the new EZ Dashboard, the device can just for the dashboard itself, but seems like a pain to rename each.
And then when I got some EcoWitt gateways, I couldn't rename the child sensor devices so I had a bunch of 'Air Quality Sensor' tiles on the dashboard that I don't know which is which. I could assign these devices to rooms so I thought I can just create rooms like '1F Bob BR' so the device name doesn't need to have that same information.
But it looks like Rooms are not synced over the Mesh. I have a mesh with a c8 for zigbee devices and a c7 wifi/lan devices and I just realized that over the mesh, the ecowitt sensors don't retain their room info.
Maybe I should use labels instead? Maybe it's time to implement tags?
Use the Device Label!
I use "{room} {device}" in the Device Label. I keep the Device Name for the device type. E.g.,
and
and it looks good in the device page:
This naming scheme predates the existence of rooms, but I like how this disambigufies devices as displayed by label, which everything uses when the label is set. Thus, I kept the room name in there even after rooms were added.
(and I got this scheme from older posts here dating back 4 years asking the same question).
In device label I use:
[Device Type abbrev] [Room name abbrev] [specific item in room]
In device name I include the mfg, device type and model number
I too use Short abbreviations to identify "rooms"
TVR Outlet 1 (Jasco)
FPR Pot Lights (Zen27)
KIT Motion (SNZB-06P)
And so on.
I find having the Dev type or model in the Device Label helps me when I'm troubleshooting or writing rules, even though the same info is often in Device Name.
S.
I use 2-4 letters to describe the room, an emoji to describe the device, and a short description of the function/location. I like the short descriptions as they tend to fit better on a phone screen.
KTN :running_man:t2: hallway
Kitchen motion sensor in the hallway.
EXT :door: alley
Exterior contact sensor on the alley gate.
For hub mesh linked devices I just added a simple link emoji.
GAR :bulb: entry :link:
KTN :twisted_rightwards_arrows: pantry :link:
The last one is a switch. I didn't find a better icon.
I don't typically mark child devices.
Edit: I like the emojis because it keeps the names short and it is easy to tell the device at a glance.
Good idea on the emojis.
So it looks like using labels will override the device name and labels do work for mesh devices.
When using the mesh the device names still come in with a suffix stating where it is linked from.
I just change the label to read how I want it to show up. You can't change the device name but you can change the label.
In this case the device on the original hub looks like this:
I didn't bother to change the name that was provided when I added the bulb. I just updated the label and that's what is used for the mesh with the "on Photodrome C-8" added.
For those using emoji's, do they come through on all of the dashboards and the app??
Also, sorry for the boomer question, but how do I bring up an emoji screen on the Device Label?
ETA: Just played with the HomeKit integration for the first time. It would not take device names that contain = or @ sign; I imagine it would also not take an emoji!
I copy and paste them from emojipedia.org. If you do a search in this forum on "emojipedia" you'll find lots of examples of where they work.
