Is it possible to add an option here to don't allow turn on lights on certain modes?
I know I can make some tricks to obtain the same result but with the suggested option that will save a lot of time and logic on my hub:
Motion Lighting already has such an option:
However, as you can see, that is not in your screenshot above. This is likely because you enabled the "Use per mode settings" on the first page of your Motion Lighting setup. (Once selected, this can't be un-selected; you'll just see "Use Per Mode Settings" at the top of the main page.) In this case, you're already selecting the devices and modes and when or what to turn them on -- or not -- to in a particular mode. So, simply adjusting your options for that mode should work. If you want to go back to the non-per-mode settings above, you can create a new Motion Lighting instance since this setting is stuck on once you enable it.
Great.. I have no problem to make all rules again on that app....
Impossible to see if you do not mentioned it ![]()
Thanks a lot!
