I have a Sonoff temperature/humidity sensor in the return air duct to the AC and a second Sonoff temperature/humidity sensor in the ceiling duct from the AC.
Is there a way to subtract the value of the ceiling duct from the return duct when either changes and display the temperature difference in a tile?
Using Rule Machine, create three variables. Assign your sensor values to the first two (these can be local variables) and then set variable 3 (probably a global variable) to the difference using the "variable math" operation to subtract the two. Display variable 3 on the dashboard.
You should expect supply air humidity to be 100%. And the higher the humidity in the return air, the lower your temperature difference will be (higher supply air temp).
