Greetings, I'm trying to put WiFi on hubitat. I bought the suggested adapters and everything but when I click on install driversci get stuck on "working on it".
I waited a couple days..but still same, tried to reboot, to shutdown but it remains on same step.
Any one have an idea could fix it please?
@gopher.ny any ideas?
The driver installation bit should take about a minute at most.
Here's how to reset it.
- Open Settings - Network setup.
- Make a note of the number in the URL, it looks like this: http://hubs.ip.address.here/installedapp/configure/1021/mainPage. Make a note of the number in the URL.
- Put that number in a URL like this one: http://hubs.ip.address.here/installedapp/forcedelete/1021/yes, replacing 1021 with the number from step 2.
- It should show apps list if successful or an error message if not.
Now network settings should be reset and it should no longer have a "work in progress" status indicator on WiFi.
thanks gopher as u said the work in progress is no longer there. But what should I in order to install the driver?
I tried to install it again and the same thing happens. I'm not available to install the wifi driver.
