String Question - Lazy evaluation of Strings
I'm trying to use Lazy String evaluation as explained in, e.g., Section 7 of this article https://www.baeldung.com/groovy-closures
As I understand it, the following code should be valid:
void stringTest() {
	int  thisNumber = 5
    def myString = "This Number is ${ -> thisNumber}"
	log.debug myString
I have this in a simple driver file. When It try to save the code in Hubitat, I get the error:
Anybody know why? Is this type of function blocked in Hubitat, or have I done something wrong in the code?
Change it to
def myString = "This Number is ${thisNumber}"
Thanks for the response. I'm aware of the usage you mentioned. However, the usage I'm going for is different -- adding "->" within the closure is supposed to change the timing of the variable evaluation.
With mystring as you've defined it, if you have code
number = 3
log.debug myString
number = 4
log.debug myString
The result would be
This Number is 3
This Number is 3
because "thisNumber" is defined at the time the string is defined.
If you have
With the "->" in the closure, the evaulation of "thisNumber" becomes "lazy" and doesn't happen until the string is evaluated, so the result should be
This Number is 3
This Number is 4
I'm asking because, with the new "libraries" function coming in 2.2.8, I want to define some strings in libraries and want the evaluation of the parameters to be "lazy" so the full string changes as certain variables change.
What I was trying to figure out is, (i) Maybe this is a groovy 2.2.5 or later feature, or (ii) its been somehow disabled for hubitat (possibly unintentionally), or (iii) I'm using it wrong.
thanks.
Ahhh, gotcha! Maybe a question for @gopher.ny, then.
I'd say that theoretically it should work..
Work around perhaps:
void stringTest() {
	int  thisNumber = 5
    def myStringClosure = {"This Number is ${thisNumber}"}
	log.debug myStringClosure()
    thisNumber = 6
Libraries act as includes/way to reduce code duplication. It is literally string substitution. If it works in plain code, it will work exactly the same way if put into a library.
Not sure about the origins of this exception other than it comes from Groovy parser.
