Hi , hoping someone can help or explain the following :
I have setup a Virtual Switch in Hubitat and I can control it through webcore.
The issue is that i did the following :
1- With Virtual Switch
2- Turn on
3-Refresh the Virtual switch
I normally always use the Refresh for physical devices but i inadvertently used it for a Virtual Device.
What i noticed (and validated in the logs) is that the Virtual Switch does get "Turned on" but then gets reset with the Refresh.
any idea why ?
eibyer
2
Check if the virtual switch auto-turn off is not enabled in the device setting within HE.
eibyer thanks for your quick response ..
I will do that when get home ... and i dont have the remote connection plan.
Your response is intriguing.... I have seen that setting but unclear what its set at.
Is this something you have experienced as well ?
eibyer
4
In the Devices section of HE. I had encountered this before when it was set to auto-off after a few seconds, I don't remember how it was set.
![image](https://community.hubitat.com/uploads/default/original/3X/2/6/26da6159d3de4a531c2b830907cf24965857591b.png)
