STR Code Manager Feedback & Help to recover from bad data that won't delete
Somehow got into a state where there's a booking for a non-existent property. I suspect it got left when I was playing with listings and deleted one that had a booking. I haven't wanted to attempt to recreate the bug since there's no cleanup I can force/it'd make it worse.
app:12262025-12-21 08:34:37.790 PMerrorjava.lang.NullPointerException: Cannot get property 'locks' on null object on line 354 (method editBooking)
Attempted to fix this via:
  • re-add "locks" to give me something to match to, but no benefit there.
  • Adding and removing the built in app doesn't seem to clean things up.
Recommended way to clean this up? Is there a method I can get to the shell and remove related files themselves? (This is really what I need help with, all other comments in this thread below are about making lock control usability better and having a more stable platform)
Enhancement/Fix Request:
  • When uninstalling app, need to clean all the bits up, or to force removal of a listing or booking.
  • Property is more useful than "Listings" - Would be great to revert language (looks like things were property in error messages) references from Listings to Property.
More broadly a General Comment for stability and cleanup:
Really, this is an enhanced function to Lock Code Manager. The reason I was playing with this was the temporary code functionality - the gap is essentially the need to have a code work for a date range... temporary visitors to my house for instance. Observing the behaviors it feels like similar things are done in log messages (code reuse?) - and potentially conflict with eachother or the devices like having PIN Code length settings applied on locks.
So, thinking all the use cases for both apps I can come up with, it feels like these two could be better managed functionality wise as a single integrated app - something like "Property/Lock Group" to handle groups of locks and the rotation time for non-permanent lock codes. And "User/Booking" that uses a selection of "Property/Lock Group", with the ability to select 'Permanent' or 'Date Range' This'd then allow for a single UI approach and common code for the underlying logic, if you're already not calling the same routines.
The other use case I had to the two above was "Recurring Access" for specific day or hour ranges. Like saying a code works 9-5 M-F (an employee) or Every other Tuesday for a cleaning crew etc. This scenario is a bit more "nasty" for lock programming since it'd have to add or remove from the locks a LOT I'm not sure zwave locks and the underlying programming retry logic is solid enough to implement this frequency of changes, but it would round out the only other activities I could think of.
I only just learned about the STR Code Manager. Previously, I've been doing this with a mix of Google App Script coding and Rule Machine on the hubs at my various AirBnBs. The idea of this being baked into Hubitat is exciting. Problem for me is that I haven't been able to find any documentation for this app, nor much in the way of feedback on how reliable it has been for other users.
How has it been performing for you, and have you noticed any tips/tricks/hurdles to be aware of? Are you aware of any official documentation for this app?
As for the "Recurring Access" use case you mentioned, adding/removing codes can run batteries down more quickly. (I learned this through testing my own program for adding and updating the codes for my cleaning crews.) I would recommend per-user codes for the employees, and then setting up logging and alerts for if the codes are used outside of expected hours. It's a more reactive stance, but it'll reduce your battery burn.
