Home assistant is great, but no other like hubitat to handle Zwave devices. I want to store the codes i set on my lock on a virtual device, so i can expose it to Home Assistant. For Example:
-Lock Code 1: 1234
-Virtual Temperature Sensor: Lock Code 1 %value% (This sensor will be share to home assistant, so i can see that value on a entity.)
I set the value the codes values on Home Assistant, i want this option to confirm that se value was successfully set.
