Hi,
I've had a look on the forum and I can't seem to find exactly what I'm looking for. Hopefully someone on here can help.
I have 5 light switches. They control different physical circuits but are all part of an open plan living area. I've created a rule that turns on all switches when a single switch is pressed. So no matter where you are in the room you can control all the lights.
The problem is that these switches are touch sensitive and if someone presses the switch too long, or people aren't sure how to use the switch and press it twice, the off function is activated. With there being so many switches that means there can be "on" and "off" commands circulating at the same time leading to them getting stuck in an on / off loop until I pause either the on or off rule in the app. It also ends up removing the devices from the network because their hard reset involves pressing the switch times. Without some kind of pause or more clever logic in the rule, the infinate loop always ends up being triggered.
To be clear I've made one rule for "on" and one for "off" rather than a "toggle" command to try and increase reliability. I also tried setting a private variable justpressed with a 5 second count down (when on is pressed, the off rule shouldn't be able to to be fired for 5 seconds). But neither seem particularly reliable.
I'm wondering if anyone has any advice on how to increase the reliability of the rule, or alternative ways of making this work.
Trigger:
Switch - Hall Down 1, Switch - Kitchen Hall 1, Switch - Kitchen Rear 1, Switch - Kitchen Boot 1(off, on, off, on) any turns on
Action:
IF (Variable just-pressed(false) = false(T) [TRUE]) THEN
On: Switch - Hall Down 1, Switch - Kitchen Hall 1, Light - Kitchen Strip, Switch - Kitchen Rear 1, Switch - Kitchen Boot 1
Set just-pressed to true
END-IF
Delay 0:00:05
Set just-pressed to false
Thanks!
