still getting these errors in the logs. and i delete and recreatee the two rules that had a resume and none are in motion lighting which is app 37,, any other ideas. thanks
Click on the red error, and it will open whatever app it is.
Or go to hub-ip//installedapp/status/37, where you will be able to remove it.
i isolated the erroir to these pause and resume all in rule machine even though the error is in motion..
the pause and resume are not working.. i even deleted and recreated the rules.
these did work before my firmware update and restore.. i even did a soft reset..
any ideas how to fix this..
thanks
interesting.. i fixed it by manually pausing the rule then the pause resume started working with no errors.. '
very weird
