moved my Hub to another router and set it to static before moving and can no longer find hub, I know the MAC address, ran Advanced IP scanner and unable to find it
connected it back to the original IP address range and still unable to see it
find my hub shows at the old address but unable to connect
Best bet may be to do a network reset by pressing the small button underneath the hub.
Thank you , had to hold it for about 15 seconds then it picked up a IP address
7 is enough. Once you let go it reboots
