After each huge loop, that device finally turns on or off. That’s all I can tell.
I split dimmers and switches into separate groups. I tried the optimization on and off. I tried a 10ms delay.
Do you have a secondary controller (like a UZB3 stick, UZB7 stick, or Aeotec z-stick)?
No. I ordered a C7 last night. Not sure if it will help or not. I really like this hub but my wife is getting pissed off with the delay. Especially when she tries to go to bed and lights don’t turn off or on
I experienced slowdowns on my C-5 ONLY after I created half-a-dozen stranded z-wave devices. @bobbyD helped me figure out there were stranded devices, and I used a secondary controller (UZB-3) to remove the stranded devices.
My C-5 had no more slowdowns after that. Last year, I migrated the C-5 network to a C-7, and it continues to function well.
Unfortunately, unlike C7 model, the C5 is not very good at showing or removing ghost nodes. There is a nightly task that runs on the hub that attempts to remove hidden ghosts but is usually not very successful because the radio tends to hold onto dead nodes for a long time. Presence of dead nodes in your mesh will certainly introduce latency and can make your mesh unresponsive at times, which is consistent with your experience. I've seen your ticket coming through yesterday and will dig into your hub tomorrow morning to see if I can narrow down the problem.
Sweet. I posted here already but I’ll reply to you with it. The delay seems to be the hub polling each device hundreds of times before moving onto the next one. I just tried a scene and it does it too.
Do you have Z-Wave Poller enabled?
Also just read this comment:
That sounds like the problem may not be Z-Wave related.
That happens with Alexa integration. It may or may not have been temporary.
I do not have any devices that "qualify" for polling so i do not have i installed.
