I've been using a C-5 hub for several years. I recently decided to upgrade to a C-8. Rather than going through migration, I decided I wanted to remove devices on the C-5 and add them to the C-8 and set up fresh applications/rules and possibly eventually use Hub Mesh. In any case, I started with some new Zooz devices (a couple of the new ZSE70 outdoor motion detectors, and a ZEN37 remote), and I also moved an older ZEN24 toggle switch over. I had a few false starts setting up one of the ZSE70 in LR mode but got things mostly working.
It may have been my rushing the setup and overlooking some best practices but I ended up with some strange results:
- I'm pretty sure that when I added the ZSE70, it showed up on the Z-Wave details page with an indication it was in LR mode. At some point, that device wasn't shown on Z-Wave Details anymore even though it existed in the devices list and was working properly (motion was detected when viewing the device).
- I decided to exclude/remove all the devices and now have no entries in the device list but I still have two of the devices in the Settings Z-Wave Details table. It may be related to when I removed one of the devices I got "Unknown Z-Wave device excluded" instead of the named device being excluded and removed.
- If I try to Remove one of the entries after shutting down the hub and powering it off for a while, I get "Z-Wave Network responded with Busy message" log entries.
- Throughout all of this, If I view the Z-Wave logs, it is empty. I don't know if that's normal or not.
All of this is just background for why I just want to start over and pay more attention as I go through setup. I don't really care to track down how I got to the state I'm in. My two questions are:
- Can I go into the Diagnostics Tool | Advanced | Full Reset and will it be as if I just opened the box?
- Is the Network Busy a result of the state I put the C-8 into (and if I start over it will go away) or is there some type of interference between the devices on the C-5 and what I do on the C-8?
Any help or comments would be appreciated.
