Wondering why my fob's are showing 0% battery since I added them to HE and my dashboard. They are ST V2's (I believe), they do work fine for presence, just the battery icon is not correct. I did do the battery mod with a pair of AA Lithiums for what it's worth so I know the voltage should show around 100%. Thanks, -Joel
What battery percentage is shown in the driver details, and what driver is being used?
My St fobs di this if I don't put the right battery in.
As in the brand. Can't remember which atm.
Same here and I did the battery mod. Didn't check to see if it was reporting correctly before the mod though.
Hi Mike, Under "Current States" it says "battery: 0, presence: presence".
When I added it, it looks like the hub picked the built-in SmartThing Presence Sensor V2 driver. I just hit the Configure button for grins but no change. The fob works correctly for presence though.
I did the battery mod (powered by 2 AA lithium batteries) as the battery life with the 2032 coin cells were not good. Thanks for the help. -Joel
looks like the DH is not reporting battery status correctly for V4 sensors either.
I can see the battery value in the live logs but not the device events
sensors still work fine though
I am sure the battery value worked fine before but I really have not kept an eye on it
I have a rule that notifies me of low batteries and remember getting notified of low batteries from these in the past.
Hey Mike, I'm not showing any battery info coming from the fob at all with logging enabled like @NoWon. I am using the driver that HE picked (SmartThings Presence Sensor V2). I just looked mine up, it's the original egg shaped one. On the SmartThings website it's called the " SmartSense Presence Sensor". Does this make a difference?
