ST Presence Fob v4
Hi Guys,
Not sure how many got the v4 ST presence Sensor but im going nuts. Was the ladt thing for me to move from SR but i cant seem get it to work.
The Sensor is paired fine but it's always going to not present after a while.
I can be at home for an hour an triggered the leave/arrival quite a lot of times.
As such I can't use it to trigger arrival/leave automations.
dev:1862019-03-04 14:52:47.635infoSmartThings Presence Sensor V4 has arrived
dev:1862019-03-04 14:48:23.996infoSmartThings Presence Sensor V4 has departed
Just an Example of what happens several times during the time I'm in.
The battery check-in every 30 secs as it can be seen on the logs.
dev:1862019-03-04 14:39:43.890warndebug logging disabled...
dev:1862019-03-04 14:39:43.590debuggetBatteryResult- value:28
dev:1862019-03-04 14:39:43.569debugST presence sensor, reporting in...
dev:1862019-03-04 14:39:23.589
I purchased two and they arrived yesterday. I paired just one yesterday and it's (correctly) showing present and has never changed. Which matches it's real condition. It should move for the first time later today.. I'll find out then if it's worth unboxing the second. :slight_smile:
Mine were doing this as well. I have a feeling something in 2.0.6 changed how they are reporting. Unless it sorts itself out (either by the HE team or the sensors themselves), I'm using Life360 as my main presence driver.
I cant rely on mobile presence alone as I often leave the mobile at home when jogging or going for soccer.
my V4 are reporting presence correctly but the battery is not reporting reliably.
Seems to report battery when i first change the battery out (so power cycle) but then appears to stop.
All of mine I have modded the battery to AA rechageable batteries.
Fairly certain battery reporting worked before with this mod but the batteries last quit long (3-4 months) so hard to remember.
It maybe a low battery causing your issues though mine does that when the battery gets low.
looking at your live logs it says your battery is at 28
On my device page mine was saying it was at 70% but my live logs showed 22 so I changed out my batteries and it is reporting presence fine again
I wonder if the battery reporting has something to do with the firmware? Like the expected mAH (~230, I think)( is hardcoded into the firmware for the sensor perhaps?
I would tend to agree, but I changed the batteries in my sensors before I paired them with HE. Mine are currently reading 80 in one and 95 in another. But, both of them seem to "leave" and then arrive every 5 minutes.
Ahhh, gotcha. My phone goes with me everywhere.
what does your live log report for the battery reading? (not the device events)
LOL Even worse:
dev:1192019-03-04 10:47:34.622 am debuggetBatteryResult- value:20
dev:1192019-03-04 10:47:34.577 am debugST presence sensor, reporting in...
dev:1372019-03-04 10:47:32.072 am debugcondition: 1009 | condition text: Overcast | condition factor: 0.5 | lux: 3429
dev:1372019-03-04 10:47:32.068 am debugbetween sunrise and noon
dev:1192019-03-04 10:47:14.640 am debuggetBatteryResult- value:20
dev:1192019-03-04 10:47:14.609 am debugST presence sensor, reporting in...
dev:1192019-03-04 10:46:54.686 am debuggetBatteryResult- value:20
dev:1192019-03-04 10:46:54.652 am debugST presence sensor, reporting in...
On the device status page, it says 50:
Current States
  • battery : 50
  • presence : present
could be simply a bad battery right off the self
My live logs:
dev:9352019-03-04 07:49:42.463 am warndebug logging disabled...
dev:9352019-03-04 07:49:33.479 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:49:33.454 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:49:13.542 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:49:13.520 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:48:53.611 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:48:53.585 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:48:33.680 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:48:33.649 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:48:13.741 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:48:13.714 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:47:53.809 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:47:53.776 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:47:33.851 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:47:33.833 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:47:13.928 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:47:13.908 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:46:54.016 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:46:53.972 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:46:34.063 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:46:34.035 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:46:14.128 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:46:14.103 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:45:54.189 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:45:54.165 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:45:34.255 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:45:34.232 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:45:14.319 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:45:14.293 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:44:54.390 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:44:54.357 am debugST presence sensor, reporting in...
dev:9352019-03-04 07:44:34.451 am debuggetBatteryResult- value:26
dev:9352019-03-04 07:44:34.425 am debugST presence sensor, reporting in...
Current States
battery : 100
presence : present
Perhaps, but in order to avoid that, I never update any of my sensors from the same pack. I've been burned by buying battery packs before that were completely bad. LOL (I'm a bit OCD about my batteries).
This is a brand new sensor. I just took the stick that was protecting the battery.
However just in case I have a battery tester and I tested the battery... it shows off as full. So battery reporting is not accurate
are both of you using stock batteries or have you modded the units?
Stock...
Side note does anyone knows how to use the key finder ability of the sensor?!
Stock
Wait... what?! There's a key finder ability? Are you referring to the tone thingy? I think I got it to work ONCE on ST. I've never tried it on HE though.
That's the one :joy:
thanks all mine are modded so was not sure if that was causing my issue
but apparently not
key finder I think it just made the sensor beep I tried it once on SmartThings but have not seen it on Hubitat
I forgot all about it
