bdruth
March 30, 2023, 2:11am
1
Mea culpa. I'm an idiot.
I didn't update the private key field when updating my SSL configuration, only the certificate, and now I can't access the Hub UI over https. I've also enabled HTTP->HTTPS redirect, so ... now what?
Any "in case of emergency break glass" that I can do (ideally w/o losing my entire configuration).
Have you tried port 8081. Otherwise reach out to support.
There is a reset button on the bottom not sure if a long press may do more then just a network reset but it is worth a shot.
bdruth
March 30, 2023, 2:43am
3
signs of life on 8081!! thank you!
bdruth
March 30, 2023, 2:45am
4
OK, so, 8081 gets me into a menu, but I'm not sure how to fix the SSL settings from there?
Try safe mode maybe? Otherwise you might have to restore a backup.
bdruth
March 30, 2023, 3:01am
6
Safe mode didn't work, but soft reset did and I can restore a backup I downloaded from the :8081 interface.
For future reference, the hub endpoint mentioned here should help, I think:
Didn't find any issues with HTTPS setup, so fire away. Let's call it an extended beta.
To set up HTTPS, go to http://your.hubs.ip.here/hub/advanced/certificate , copy/paste certificate/private key and save. Once saved, reboot the hub for the setting to take effect.
There's an option of SSL only on the screen. I suggest testing HTTPS connection before turning it on.
If something doesn't work, you can disable SSL by going directly to http://your.hubs.ip.here/hub/advanced/disablessl . You should …
system
Closed
March 29, 2024, 10:40am
8
