Spruce Connect
I get this error when trying to install the Spruce Connect App.
No signature of method: Script1.definition() is applicable for argument types: (java.util.LinkedHashMap) values: [[name:Spruce Connect, namespace:plaidsystems, author:Plaid Systems, ...]] on line 47
Any ideas?
THANKS!
like this:
It's because you're trying to install an App in the Drivers Code section. Try pasting it into Apps Code section instead.
The package is one App and several optional drivers. Driver code goes into Drivers Code folder, Apps go into the Apps Code folder. This package is NOT in HPM, which would have prevented your issue.
Well duh...thanks.
Sadly, spruceirrigation.com seems to be down. Both in trying to connect and going straight there. Maybe server work on a Sunday?
On the other hand, I sent their TAC two q's in the last week with zero response...and their Gen 3 sensor sales link is broken going to Amazon. Both those things are a bit worrisome.
I had mine for around 3 years...but there was no integration with Homeseer.
