I need to implement some sort of checks and balances for my sprinklers. I have Rachio 3 controller integrated into Hubitat. I had to create a rule that polls the system about every minute (I do this from 12:01 am - 9am) because it won't get push updates. I have 3 zones hardwired to the Rachio, and 4 controlled by Zooz relay controllers. I created rules (see example below) that when Rachio valve changes, the Zooz relay will respond accordingly. However, I have had a couple of instances where Rule Machine fell flat and didn't turn the valve off, even though the logs show the change on the Rachio side (logs provided below as well).
I'm wanting to do one or more things. 1) Insert in the rule if the valve is on for x amount of minutes turn off the valve (need help inserting this). 2) Have Rule Machine reverify the condition of the valve in Rachio to match the Zooz relay. Thanks in advance for any guidance.
Rule:
Log showing Rachio updates:
dev:10972023-06-02 02:57:30.656 AMdebugUPDATED: Watering set to (off) | Original State: (on)
dev:10972023-06-02 02:57:15.059 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:57:15 AM)
dev:10972023-06-02 02:56:30.589 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:56:30 AM)
dev:10972023-06-02 02:56:14.986 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:56:14 AM)
dev:10972023-06-02 02:55:30.618 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:55:30 AM)
dev:10972023-06-02 02:55:14.880 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:55:14 AM)
dev:10972023-06-02 02:54:30.638 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:54:30 AM)
dev:10972023-06-02 02:54:14.828 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:54:14 AM)
dev:10972023-06-02 02:53:30.585 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:53:30 AM)
dev:10972023-06-02 02:53:14.734 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:53:14 AM)
dev:10972023-06-02 02:52:30.606 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:52:30 AM)
dev:10972023-06-02 02:52:14.700 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:52:14 AM)
dev:10972023-06-02 02:51:32.235 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:51:32 AM)
dev:10972023-06-02 02:51:31.999 AMinfoRachio - Fruit Garden is (Online and Active) - Last Updated: (Jun 2, 2023 - 2:51:31 AM)
dev:10972023-06-02 02:51:31.936 AMdebugUPDATED: Watering set to (on) | Original State: (off)
Logs showing Sprinklers went on at 2:51 am, but it was a manual shutdown at 5:36 am
dev:10182023-06-02 05:36:54.520 AMinfoFruit Garden: switch is off
dev:10182023-06-02 02:51:33.125 AMinfoFruit Garden: switch is on
Thanks again!
