I am bringing this up again because it is still happening. It happens in Rule Machine and in Basic Rules. I have the following rule. Followed by the Log and the Settings.
This rule speaks the word Attention when it supposed to but at the end of the second speak it repeats the word Attention again. If I change the delay to 2 seconds it works every time.
ALSO: (after a hub reboot) If you run the rule 3 times manually it works fine. But on the 4th try it starts to repeat.
Please let me know what else you need.
Here is the Rule.
Here is the Log.
app:25812022-11-30 08:15:58.756 PMinfoInitialized
dev:18292022-11-30 08:15:55.650 PMinfoAll Alerts HS4 Sonos is stopped
dev:18292022-11-30 08:15:54.775 PMinfoAll Alerts HS4 Sonos is playing
dev:18292022-11-30 08:15:54.576 PMinfoAll Alerts HS4 Sonos playing: the garage double door is now closed by Hubitat from TTS
dev:18292022-11-30 08:15:54.560 PMinfoAll Alerts HS4 Sonos is stopped
dev:18292022-11-30 08:15:52.589 PMinfoAll Alerts HS4 Sonos playing: the garage double door is now closed by Hubitat from TTS
dev:18292022-11-30 08:15:52.578 PMinfoAll Alerts HS4 Sonos is playing
dev:18292022-11-30 08:15:52.348 PMinfoAll Alerts HS4 Sonos playing: attention by Hubitat from TTS
dev:18292022-11-30 08:15:52.321 PMinfoAll Alerts HS4 Sonos is stopped
app:25812022-11-30 08:15:52.244 PMinfoDelay Over: Speak on All Alerts HS4 Sonos (volume: 45): 'the garage double door is now closed'
dev:18292022-11-30 08:15:51.588 PMinfoAll Alerts HS4 Sonos is playing
dev:18292022-11-30 08:15:51.352 PMinfoAll Alerts HS4 Sonos playing: attention by Hubitat from TTS
app:25812022-11-30 08:15:51.259 PMinfoAction: END-IF
app:25812022-11-30 08:15:51.209 PMinfoAction: Speak on All Alerts HS4 Sonos (volume: 45): 'the garage double door is now closed' --> delayed: 0:00:01
app:25812022-11-30 08:15:51.148 PMinfoAction: Speak on All Alerts HS4 Sonos (volume: 45): 'attention'
app:25812022-11-30 08:15:51.144 PMinfoAction: IF (Garage DD Open/Close Sensor contact closed(T) [TRUE]) THEN
Here is the Settings.
This is from Application State.
