Hi, does hubitat allow to set non default parameters to z wave devices ?
For example i have got spirit z wave thermostat and for parameter 8 I can set offset of measured temparature.
There is a "Basic Zwave Tool" written by Hubitat. It is a driver so you must add it to the HE hub.
Once installed you need to replace the thermostat driver with the BZT driver, hit Save. Next set the parameters, and hit save. Next switch back to the thermostat driver. and hit save.
thanks, work fine!
