Would it be possible to put local variables to the top of the variable dropdown or in some way highlight them?
There probably will be more hub variables than local, most of which will not be used but local variable will always be used.
I will look at this. What about adding (Local) to each local variable in the dropdown instead?
Thanks. Yep, that would be a manual fix.
Adding (Local) turns out to be a rather difficult way to do this. I'll have to think about this one some more...
