Since yesterday (Dec 25) that's all I get, Sorry I couldn't reach the Hubitat. I rebooted everything. Still won't work. I am running 2.3.4.122. I tried reconnecting the app in Google Home and it locks the app up.
Make sure your Hubitat hub is connected to Hubitat's cloud. If you're setting a static IP on the hub itself, change it to DHCP and setup a DHCP reservation on your router. Also make sure that DNS is working.
For a start run the diagnostic network tests available under:
Setup -> Network Setup
Network setup reports no errors. It is setup as DHCP. I don't know how to check if it's connected to their cloud.
I also tried reconnecting the Hubitat in the Google Home app. This is the error I get:
"The parameter 'state' must be set in the query string.
If you'd like, please send me a private message along with your hub's MAC address or hub ID and we can check to see if the hub is connected to the cloud.
I decided to reboot the router for a 2nd time and it's working now.
