I shutdown my hub. Pulled the power at the back and plugged back in. Then I noticed my Hue bridge was on same zigbee channel (20) so I changed the channel of the Hue bridge.
Then tried to discover the hue dimmer switch and initialized very quickly this time. Not sure if it was the Hue or if it needed a reboot but working now. Thanks
Well I've removed my sonoff zigbee from my mesh as I've been having the odd random problem with my SmartThings contact sensors. I tried removing one of my other repeaters before this and it made no difference.
Once the sonoff zigbee was disconnected my SmartThings sensors are working again without having to re-pair. Interesting thing is my xiaomi sensors were fine even when in the same area as the SmartThings sensors that lost connection.
Touch early to be sure the sonoff zigbee was causing problems with my mesh, but everything is indicating that. I've now put a genie wifi power plug in its place and feel that device running tasmota is better anyway.
Since they use a CC2530 chip without any amplifier the signal is not very strong, this can be problematic depending on the device that connect through it.
Si manualmente toco ese interruptor, luego no ejecuta correctamente las rutinas. Es decir, para que me funcione adecuadamente tiene que estar el interruptor fisico en una posicion de cerrado.
