HE integration with Sonoff WiFi devices with native/original firmware not exists yet.
I'm aware about several integration with Tasmota original & customized firmwares, with and w/out MQTT usage. But still hope to avoid all that stuff with soldering and flashing.
Ah I see. I believe there's a method to flash the tasmota firmware without opening the device and soldering. But flashing the firmware is still probably the only available method to get local control with Hubitat.
I know I'm a newbie to Hubitat but with the Sonoff DIY mode it looks like controlling those (R3 DIY) devices could now be done by just sending some simple code without all the tasmoto work. Just not sure where it needs to go. This link looks pretty simple, I must be missing something.
sonoff.tech/product-tutorials/diy-mode-to-control-the-sonoff-device
I'm new on hubitat stuff, though, i managed to successfully build a driver for my Sonoff Mini Switches, based on the native sonoff firmware.
Is running successfully for a few days now and it seems to be quite stable.
Feel free to give it a spin and if you have improvement ideas, just let me know on git.
You can find it on GitHub, by: rusulucian85/hubitat-Sonoff_DIY_Switch
thank you for this code.
But I am facing one problem with thsi driver that it works from the HE to the device and not the other way around.
if you toggle the command from the HE, the device will update. but if you toggle the state from the device like ( short the s1 and s2 on sonoff miniR2) the device will change state but it will not update the HE.
I have tasmotized few miniR2 and i use a driver with httphook where you enter the ip of your hub and it works both ways instantly.
i have looked at your code but i am not a programmer. is there a way you can modify the code so that it will update in both ways.
thank you
