Sonoff SNZB-03P Sensor
This is an oridanry PIR sensor, it is supported in Tuya Zigbee Multi-Sensor 4 In 1 driver.
Change the driver, then select 'Load all defaults' from the Configure drop-down menu and click on the Run button below.
Refresh the device web page, in the State Variables the device profile should be set automatically to SONOFF_SNZB_03P
If the motion sensor does not work, pair it once again to your hub (without removing it!).
