Please help me understand how to fix an issue with two Sonoff S-31 lite Zigbee devices.
Since I upgraded to xxxx.40 on the C7, both of my devices have turned flakey. Maybe just coincidence. Regardless, how do I fix it? Do I need to delete all the automations associated with these devices, then delete the devices, then repair, then redo all the automations? That seems like ALOT of work. If no, what is the procedure for just getting these things reconnected to HE?
Both devices: Light turns on and off by the button on the S31, so we know the device has power, the fixture is working and the bulbs are working.
After reading around the forums, 48 hours ago I changed the Hub Zigbee settings to channel 25. That did not help.
Device A:
Device Log reports to HE about every 5 minutes, but if anything occurs to trigger the light to go on, the device stops reporting. I turned device on from HE about 20 minutes and since then it stopped reporting.
Event log has not reported in about 5 hours, but yet I turned the device on 20 minutes ago from HE, via the device interface. But that action of turning it on is not in the Event log or the Device log. Also, I can no longer communicate with the device from HE - I cannot turn it off.
Device B:
No connection to HE - can't turn it on or off via the device interface or via any automations.
What should I do? These were working fine for 3.5 months and then this suddenly happened....
I can no longer control
