Sonoff S26R2ZB compatibility?
Hello there!
So I rather hastily bought a pack of these babies
Looks like they come in UK and EU flavours and they're super cheap. I see people just buying them to extend the zigbee network, though I am intending to use them as switches.
Anyway, they list Samsung and a bunch for compatibility, not habitat though that's not very surprising. They discover and putting them on Generic Zibgee Switch shows a status, but they don't seem to respond to On and Off :face_with_raised_eyebrow:
Anyone else had luck with these guys?
Did you click Configure after changing drivers to Generic Zigbee Switch?
I did not, good spot. Just tried that now though and it's no better.
The status changes nicely in the UI when I press the little button on the gizmo, but no luck the other way around. :frowning:
Possibly a bit late now that you've already bought the Sonoffs, but the SmartThings UK Socket is recently around £16 on Amazon which is a steal for a great quality socket that also supports power metering.
Well that is interesting, I'm certainly not beyond sending them back and getting those. Seems a shame though, so close.
Also, these suckers are £25.65 for 4, that's like £6.50 each! But that's very expensive if they don't work :slight_smile:
could you try another driver? There is some nice Sonoff outlet support in this:
https://raw.githubusercontent.com/markus-li/Hubitat/development/drivers/expanded/zigbee-generic-outlet-expanded.groovy
Thanks for this, what repo does that come from can I ask?
I did try it, I don't this that's any better I'm afraid.
dev:3532021-10-20 18:13:25.455 infoBIND RESPONSE CLUSTER EVENT
dev:3532021-10-20 18:13:25.217 infoINCOMPLETE - DO NOT SUBMIT THIS - TRY AGAIN: fingerprint model:"null", manufacturer:"null", profileId:"C05E", endpointId:"0D", inClusters:"1000", outClusters:"1000"
dev:3532021-10-20 18:13:25.213 traceApplication: null
dev:3532021-10-20 18:13:25.207 infoNOT IMPORTANT: Application ID is missing for the fingerprint, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3532021-10-20 18:13:25.202 traceModel: null
dev:3532021-10-20 18:13:25.198 traceManufacturer: null
dev:3532021-10-20 18:13:25.195 warnManufacturer name is missing for the fingerprint, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3532021-10-20 18:13:25.190 debugGetting info for Zigbee device...
dev:3532021-10-20 18:13:23.391 infoSKIPPING ping() since there has been events received during the last 25 minutes...
dev:3532021-10-20 18:13:23.321 infoRecovery feature ENABLED
dev:3532021-10-20 18:13:23.267 infogetDriverVersion() = v1.0.1.1123b
dev:3532021-10-20 18:13:23.228 infoinitialize()
The fingerprint stuff - This great driver queries the device and creates a fingerprint of what the device can do, it originally asked that you send that info to the developer so he could add it to his driver to build a list of sorts. He is no longer directly supporting this driver!
Don't be put off by the log messages, they were there to help during this identification process - the driver will still function - I should have warned you'd see that but to ignore it.
I have some devices that didn't work well with the generic drive and switched to this and it solved me - I was just hoping you might benefit as well. It comes from this Github Repo:
Sir! You are a genius!!
I used the generic switch driver from that repo and it worked like a charm!
Thank you for helping me out. Now I think all should buy these for £6.50 a pop and pimp your sockets with this driver :smiley: !
awesome! so... I will note why I'm so aware of that driver. - It has a Presence built in which is totally cool. it will refresh automagically. I myself modified it so it didn't show up as a Presence device when I was building rules. but Yea. Markus is a genius and I'm just plain glad to help someone by pointing it out.
Hi, this is also worked for me which is brilliant, but child devices were created for the single socket. Did you get child devices? If i disable the option 'Enable Multi Endpoint Discovery' then the switch stops responding to ON/OFF.
Will having fake Child Devices use up the total Device count?
I did get child devices, I was content to leave them. I can't talk to the total device count I'm afraid.
Hi @Confused_Penguin I too have some zigbee Sonoff S26 plugs that I want to connect. Although I'm not entirely new to home automation, I'm very new to Hubitat (so far I have only installed natively supported devices) and I would appreciate your guidance with one step of getting this to work.
I've installed the T4HE Tasmota for Hubitat Elevation app and drivers from markus-li, as you recommended. But how do I now add an S26 plug in Hubitat? I have clicked to manually add a device but what should I do to "make sure the device is connected to your wifi"? What do I put for the IP address in the below screen?
Thanks in advance!
The S26 Sonoff Plugs come in WIFI, aka Tasmota (ip needed).
Or S26R2ZB - ZigBee (different DRIVER ) also available on HPM.
Oh, d'oh! I did think it rather bizarre that any zigbee device should be connected to wifi in some way. I was aware Sonoff also make a wifi version of this, but stupidly it never even occurred to me that they would have called both of them S26 – one model just with a suffix! Thanks for the pointer to the other driver :blush:
The suggested driver isn't doing it for me. It works for a few minutes, during which time it's spamming the log every 10 seconds exactly - unless I turn off logging altogether. And then it stops responding to on and off commands and I have to re-pair it.
Searching GitHub for S26R2ZB reveals tons of complaints about Sonoff S26R2ZB performance, especially on its Zigbee routing functionalities... Better to be avoided IMHO.
As it happens I have a workaround! I paired it to my Hue Bridge which turned out completely trouble-free and shared it to Hubitat that way :smiley: Not my favorite solution as it feels kind of "messy" but I'll survive.
Spoke too soon. It repeatedly becomes "unreachable" even with Hue. And Sonoff themselves claim Hue compatibility. At this rate I am not sure I'd even trust it with the Sonoff hub.
